355 f/s
Old Apr 19, 2007 | 02:31 PM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
355 f/s
Rebuilt 350 bored .30over new everything from top to bottom. Has stock intake with a carb setup. 86- up 350 2blt with center bolt rebuilt heads. Has distributer, Water Pump, Power steering pump and alternator, All in more then good shape. I live in Pa But am Willing to go up towards new york, Or over to jersey. Im willing to trade for a decent running Iroc that needs work such as paint, interior and trans. Or I wanna get atleast $1200, Advance sells motors such as this one for 2500 with everything I got. Its already broken in and has less then 10mi Ran really well with the junk carb set up it has.
Also have pics upon requests.
Old Apr 19, 2007 | 09:10 PM
Car: 86 Iroc-Z
Re: 355 f/s
Its gotta go soon....
Old Apr 19, 2007 | 09:52 PM
Car: 86 Iroc-Z
Re: 355 f/s
lobe lift 194 casting heads, Center bolt earyl style Vortech heads.rebuilt
in. .2730
ex. .2828
Old Apr 20, 2007 | 09:01 AM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Re: 355 f/s
Originally this said: Where are you located? However, I can't read, I see it above. What I would like to know is the cam specs - duration and lift at .050, and specifically, what are the heads, are they vortecs? Camber size? Whats the intake? 2 or 4 bolt mains? Dyno results and or track times?
Old Apr 20, 2007 | 05:14 PM
Car: 86 Iroc-Z
Re: 355 f/s
Im on the eastern side of Pa about 80miles from ny
lobe lift journal diameter
intake: 1.8682 exhaust: 1.8962.
in. .2730
ex. .2828
2bolt mains. everything is new
Its a stock 350 bored out it has nothin speacial It never ran at the track. Odds are it makes about 260hp at 305tq its got stock 194 castings heads, Centerbolts which means they are the early style vortech heads.
Stock motor stock heads its a 86 up block it was made in canada it runs good almost no miles on it needs to be fully broken in.
Old Apr 21, 2007 | 11:11 PM
Car: 86 Iroc-Z
Re: 355 f/s
The motor was put in by a garage, They ordered it and put it in. Its a stock rebuilt block, Those are the stock specs I could find on that year 350ci. Its still up for sale.
Old Apr 25, 2007 | 04:20 PM
Car: 86 Iroc-Z
Re: 355 f/s
I wasnt given the specs on the motor when it was put in the car but again it ran extremely well which it should. It was barely driven and only has about 7miles on the motor since it was pulled.
Old Apr 25, 2007 | 06:48 PM
Car: 86 Iroc-Z
Re: 355 f/s
w/ 1.94" & 1.50" valves.
------------Intake-------Exhaust
Valve Lift----Flow---------Flow
0.050--------38.7---------27.6
0.100--------70.4---------55.7
0.200--------100.2--------115.6
0.300--------145.7--------125.8
0.400--------164.7--------138.9
0.500--------178.9--------146.8
Old Apr 25, 2007 | 09:46 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 355 f/s
Old Apr 25, 2007 | 09:51 PM
Car: 86 Iroc-Z
Re: 355 f/s
Yea basically what I have, A few numbers off.
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mike22115
Sep 28, 2015 04:49 AM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
