Hawk's SW LS1 3rd gen LT headers
Old May 8, 2007 | 08:52 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
LS1 3rd gen LT headers and y-pipe or true duals
These are off of my car, Hawk's 3rd gen LS1 Stainless Works headers.
1.75" primaries
2.5" collectors
no AIR
Think that's it... practically new. Only reason I'm selling is because I'm going to the 3" collector versions due to my 402ci motor and the bottle needing it. These headers made over 600RWHP with a 402 and some spray... at this point I think they are holding me back though. Also made 485RWHP NA and went 11.1 @ 126 NA so far.
New- $799
asking $725
Thanks!
-Jeremy
*Located in St. Louis, Missouri
Old May 8, 2007 | 09:11 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Re: Hawk's SW LS1 3rd gen LT headers
I'll also throw in a 2.5" y-pipe for the same price. It worked well on my old 346" motor. It will work with the double hump "Drew" crossmember and you'll sacrifice ZERO ground clearance with it.
y-pipe pics
crossmember pics (not for sale)
Old May 15, 2007 | 08:17 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
I'll also add these to the list here...
*Sweet Thunder true duals. Custom built (by me), all mandrel bends, 2.5", pypes x-pipe, 18" sweet thunder mufflers. There is also a port welded in for a wideband o2. Also, as you can see both pipes sit on the right side of your driveshaft... well ouf of the way of your torque arm. I also ran 11.1 @ 125 with these behind my 402 so I think they flow well enough.
Here's a pic of them before I finished welding and painting them with high temp black paint.
$250 + shipping
So headers and y-pipe for $725 and shipping.
or
The whole works:
Headers, y-pipe, true duals, and band clamps for $1000 and shipping.
Of course you won't need the y-pipe and true duals but I want it all gone if possible.
*I'll also include nice stainless band clamps with either exhaust purchase. All you'd need is a LS1 3rd gen and the double hump crossmember and you'd be set!
All stuff is located in St. Louis, Missouri.
Old May 15, 2007 | 08:25 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Sound clips/videos of my car with the LT's and true duals on it.
http://media.putfile.com/402-ci-GTA-n2o-dyno
http://media.putfile.com/1213121-bad-launch
Old May 18, 2007 | 03:43 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
back TTT
Old Jun 9, 2007 | 09:12 AM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
Are the headers and y-pipe still for sale? If so pm a price shipped to 52804 business address. Thanks
Old Jun 9, 2007 | 10:06 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
are those headers only available new in a 2.5 collector????
Old Jun 9, 2007 | 10:17 AM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
How hard is that true dual set to install? Does it just slip fit over the 2.5" Hawks Header collectors? Do you have to unbolt the headers to get it all together. I am running a similar set up with Drews Crossmember, Alston Torque Arm and Hawks Longtubes. I'm interested but it seems like it would be a very tight fit. LMK
Old Jun 10, 2007 | 06:17 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
The true duals just bolt right up. I custom made them for use with Hawks SW LT's, drew x-member, Alston tq arm, and great ground clearance. They are slip fit like you mentioned.
Old Jun 11, 2007 | 06:27 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
so do you still have the headers?
1992rs/ss
16
Jan 28, 2016 09:58 PM
69 Six Pack
Oct 5, 2015 07:51 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
