350 engine for sale
350 engine for sale
I have a 1990 truck motor 350. It has brand new bottom end bearings, all oil clearances have been plastiguaged and are good, Also has brand new summit pistons. The motor is not completely assembled, but the whole crankshaft, and pistons are in, just needs the oil pump, and cam / timing chain installed. It also come with two sets of 305 heads. The cam it comes with is a bran new ZZ4 roller cam. This motor come with everything to complete the build, all gaskets, roller lifters, everything! I am only asking 450 OBO. This is a good deal, that cam alone retails for 250ish brand new. contact me at volumebikertom@yahoo.com for more info. I live in new smyrna beach florida just 10 minutes south of daytona.
forgot to add, this is a tune port motor, all of the tune port parts come with the motor, intake runner, injectors, etc.
Last edited by volumebikertom; May 14, 2007 at 03:13 PM. Reason: Automerged Doublepost
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: 350 engine for sale
Selling the heads separately? Got casting numbers if you are? Are the assembled? And price
thx.
thx. Senior Member
Car: 86' Trans am
Engine: 85 LG4-non cc carb(building a 350)
Transmission: Rebuilt 700R4,vette servo,2200stall
wish i had money....would u consider any trades??? i got a pocketbike worth $600 and a go-kart?? worth a try lol
dang, the go cart is pretty tempting, but the point of selling this is to try and cut down on the amount of stuff and hobbies I have, lol, so trading wouldn't help to much man.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i see you are planning on running a roller cam in this engine, but was it originally a roller motor? the bosses to hold down the spider are there and the lifter bores are machined flat to accept the dog bone retainers, but the bosses don't appear to be drilled and tapped. were you intending on running a retro-fit roller?
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
PM SENT. INTERESTED
Would you be around this weekend for a pickup?
SHAWN
SHAWN
Yes, normally the dots on the pistons should all be arranged facing the front of the motor. Unfortunetly I had a freind who works at a engine shop press them on for free, This is how the ended up, I was mad, called summit tech line and asked them if there is a difference. They said no, the pistons will work missmatched and facing all different ways. The dots and lettering are simply for if the motor is rebuilt again after using these pistons, then the dots are there to ensure proper alignment. So the pistons are exactley the same either way.
I gotta take my name out. Looks like i will be going to the beach for the forseeable future. See you when i get back. bump for you
NinjaNife
Aug 23, 2015 11:49 AM
