52mm BBK throttle body $160.00 for 89-92 TPI
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
52mm BBK throttle body $160.00 fits 89-92 TPI, ported + polished inlet opening. works great!
Engine: ls1, LB9
Re: 52mm BBK throttle body $160.00 for 89-92 TPI
here are the pictures. the IAC housing does not go with it. you need to swap your stock one on to it.
lots of miles...
lots of miles...
Engine: ls1, LB9
one more try
it just won't do it in this thread
Engine: ls1, LB9
Car: 1987 IROC Z/28
Engine: 5.0L TPI. Custom Tune
Transmission: 5 Speed/ Pro5.0 short /hurst stick
Axle/Gears: 1LE 10 bolt Rear/T2R 3.45 PBR/disc
From my searching, it looks like very well built 350s need BBK, i'm not sure about 305. I am planning on a new chip burn, but I am curious what else is required.
Brian
Engine: ls1, LB9
89-up use a cable to pulley style linkage. the only thing you would need to buy is a 89-up throttle cable from the dealer or who ever sells one as well. the cable will replace yours perfectly nothing else needed. I would figure a custom tune would get the most out of it but not "needed"
mdtoren
Aug 16, 2015 05:45 PM
