Parting out 4th gen. V6 Firebird in Orlando
No reasonable offer refused, Please email msteel@surgical.net w/ interest
4th GEN. FIREBIRD and /or 4th GEN CAMARO PARTS (from ’93 or ’94 3.4L vehicles)
Air box / cleaner assembly
Intake manifold
Coil pack
ECM / computer
Exhaust system complete (uncut) w/ converter and muffler
5 speed transmission
Fuel tank
Power steering pump
Rear axle assembly
Panhard bar
Anti-sway bar, rear
Shocks, rear
Springs, rear
Engine cradle / crossmember
Rack and pinion
Front suspension assemblies LT and RT, (will separate)
Torque arm
Driveshaft
Heat shield, rear muffler
16 x 8 Camaro Z28 Wheels Z28 wheels ’94 (4 available)
3rd GEN. TRANS AM GTA
Fuel tank, 3rd GEN. TRANS AM GTA
Thank You
Intake manifold
Coil pack
ECM / computer
Fuel tank
Power steering pump
Rear axle assembly
Panhard bar
Anti-sway bar, rear
Shocks, rear
Springs, rear
Rack and pinion
Torque arm
Driveshaft
Thank You
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: Parting out 4th gen. V6 Firebird in Orlando
how much for rear end shipped to 22554?
John and 89formula or anyone else that can help:
I need some advise. Both of you asked for prices including shipping. Is there a way to obtain an accurate shipping amount without buying packaging materials, (and constructing a crate in the case of the rear axle assy.) packing the part, and taking the package to the post office etc. for a quote?
i would estimate the weight and dimensions (in the case of the rear end) and call fedes/ups/et al for a quote. if im not mistaken dhl will pick up stuff from your house too...
John, I replied to your email. Thanks
89Formula, I will make some calls for an estimated shipping cost as soon as I remove the panhard bar and shocks to obtain a shipping weight.
Ssean, photo of the door trim panels should be attached to this post
try www.freightquote.com i registered and use them all the time
Car: 1990 GTA
Transmission: manual/t56
How much for the torque arm bracket(all 3 pieces) shipped to 41101? also I need the wiring pigtails for the vss,reverse lockout and reverse lights.
wigmobile
Feb 26, 2025 02:56 PM
Dragonsys
Sep 25, 2015 03:51 PM
Night rider327
Sep 25, 2015 04:47 AM
