floor pan mount torque arm
Old Sep 21, 2007 | 02:24 PM
bygblok's Avatar
floor pan mounted arm, nearly new and in great shape. Double adjustable. Asking $225 OBO Prefer not to ship. I'm in Pensacola Florida
Old Sep 21, 2007 | 05:52 PM
tylersb350's Avatar
Car: 82 camaro sc
Engine: 355 SBC
Axle/Gears: ford 8.8 3.73
Re: floor pan mount torque arm
brand, pics. pm me please
Old Sep 21, 2007 | 08:07 PM
bygblok's Avatar
I can't remember but I think it's a madman peice. Looks like the jegster but beefier and has an extra crossbar.
Old Sep 21, 2007 | 08:11 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Just a bump for you.... I used to hae one of those. Bought it brand new from MAC, before they got out of the f body biz. shawn
Old Sep 21, 2007 | 08:16 PM
bygblok's Avatar
it may be a mac now that I think about it. I had a madman peice on a 4th gen car and may have gotten them cornfused. Thanks for the bumpety.
Old Sep 21, 2007 | 11:29 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
im interested how does it bolt to the floorpan?
Old Sep 21, 2007 | 11:46 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
For install: The unit bolts into the driveshaft tunnel, usually the center console has to be removed and the carpet has to be peeled back. Then you have to drill through the sheetmetal to run the bolts through. This is the only drawback, can't refill the holes so be carefull.
This model is better then the Jegster version as it does not have a slip joint at the bushing. I went through 3 of the Jeggster units on my V6 3.4l 5spd Camaro, they REALLY take a beating, and did definately IMPROVED the handling of the car. It was just a bad design on Jeggsters part.
Old Sep 22, 2007 | 11:46 AM
bygblok's Avatar
yep, I have the instructions for it still to so you can figure up how much length to allow on it, etc. I don't have a pinion angle guage or I'd let you have it too. I borrowed one from a buddy and went +3 on the pinion.
Old Sep 23, 2007 | 01:34 AM
Car: 88 IROC
i am interested but i am worried about the pan mount. can i get some more pics of the unit if you dont mind?
Old Sep 23, 2007 | 07:15 AM
bygblok's Avatar
I'll try to get another couple of shots of it but I work two hours from home so it's a PITA to get to my storage sometimes. To add to the list I also have a brand new set of weld-in LCA relocators as well from BMR. I'll take $75 for them too. All my stuff needs to go!!
Old Sep 24, 2007 | 10:40 AM
bygblok's Avatar
also have to add my extra th350. Has a full-manual forward pattern TCI valve body in it. Stock truck internals. worked great when pulled from the car. Hasn't been used in a shade over a year. Fluid is clean. $150
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
