ZZ4 Hyd Roller Cam
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
ZZ4 Hyd Roller Cam
Hi Everyone,
I am selling my GM ZZ4 camshaft. It only has about 300 miles on it and is in great shape! Here are the specs...
208/221 Duration @ 0.050, .474 intake / .510 exhaust, 112 deg sep
Asking $75 + $10 shipping, so $85 gets it to your door!
FYI - these cams go for $200 at SDPC and $90 on Ebay (all without shipping!!!).
Thanks!
Thanks!
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Re: ZZ4 Hyd Roller Cam
im interested! Can you wait till the second week of october for payment? Do i need to change my valve springs to run this cam? Does it come with lifters?
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Im runnng this cam, u dont "have" to change the springs but then again i have valve float, and oil out the exhaust on startup :/
but you SHOULD, also it needs different valve stem seals
I would recommend using a stiffer spring... especially if your using the original springs. It's my understanding that the factory springs won't handle very much lift beyond stock. I'm pretty sure I've read that on the boards... you might want to do a quick search to verify.
Sorry, no lifters but if your engine has OE roller lifters they can be reused.
Thanks!
KamikazeIroccy,
I just noticed that you are in Missouri. Are you near
St. Louis?
St. Louis?
I guess not... Anyone else interested?
Car: '87 Iroc-Z
I stay in Columbia, Mo. BTW yes I am definitely interested in this cam. I figure getting it and buying new springs would be cheaper than buying the cam myself from TPIS its just that rent is due on the 5th and I dont think my old lady would like me being late on paying it, lol!!!
I will hold on to the cam for you until the 2nd week in Oct. FYI - I also have a PayPal account if you would prefer to pay that way.
Thanks!
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
the stock springs will work for cams with lift less than .480 anything above that new springs should be put in.
Vettoz,
ZZ4 valve springs 12551483 for $40 a set. Sign me up for that. The dealership in my area want $10.79 each or for a set including tax, about $185, and you still have to get the retainers at $2.32 each.
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
pace gmpp lt4 valve springs part #12495494,$35.95.They came on my zz4 heads.If the deals above fall through let me know.
My deal has fallen through, is anyone else interested in buying this cam from me?
U.S. shipping only
U.S. shipping only
Car: 92 trans am clone
Engine: LO3
bump for a good deal too bad i just bought mine (pullout) off ebay recently i wouldve bought this its cheaper damn you people! lol
I just took these pics... hope they show what you are wanting to see.
Thanks.
Thanks.
Car: 82 Z28
Transmission: T400
Better find a new dealer.Even allowing for their expensive shipping, GM Parts Direct has them for $30 a set of 16 or $6.65 each
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Was this the cam you were running and why are you mgetting rid of it.Any papper work to validate what it is or anything else?I`m very interested.Just want to make sure its what I want.I get paid every othr fri which is next fri.If you get another buyer before,cool.Its for another project i`m working on.thanks
I did run this cam for about 300 miles. I recently finished my first rebuild on my L98 and apparently did something wrong with a head gasket. So, I ended up taking everything apart again and figured, since everything was apart again, I would go ahead pull the ZZ4 for a little bigger cam.
I bought the cam on ebay (pulled out of a new ZZ4 crate motor) from rpd-racing (ebay id). Sorry, but he didn't provide any paperwork.
thanks!
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Not big on things off of ebay.Think I`ll have to pass.Thanks anyway.A new may cost twice as much but the peace of mind that comes with it would be worth it.Hope you dont think I wasted your time.
Engine: LO3
i just got the same thing off ebay and i measured it and such and it really is the zz4 they advertised and it was brand new. just FYI
