9 bolt 3.45 pbr/1le rear end
Old Oct 9, 2007 | 08:20 PM
chevy-man77's Avatar
Car: 89 iroc
Axle/Gears: dana44 3.73
as title 9 bolt rear end 3.45gears pbr disc brakes 350.00 if intersted i also have same rear with 3.23 gears also 300.00 will not ship rear end but will do parts ie carrier/brakes to put in your housing
Old Oct 9, 2007 | 08:28 PM
lane362's Avatar
Re: 9 bolt 3.45 pbr/1le rear end
How many mile on the gears and carrier for the 3.45 what condition is it in and how much to ship to 30241 ???? Thanks, Lane
Old Oct 10, 2007 | 05:03 PM
Car: 89 iroc
300.00 for carrier and gears shipped not sure on the miles but all parts look to be in great shape i was going to run this on my car but just came across a dana 44 that im installing instead
Old Oct 10, 2007 | 05:21 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
would the brakes work on a 10 bolt? if so how much for the brake setup including calipers, rotors and all the brackets.?
thanks
Old Oct 11, 2007 | 08:10 PM
Car: 89 iroc
see post http://www.fastlouis.com/forums/viewtopic.php?t=63412 and 100.00 plus shipping for brakes
Old Oct 12, 2007 | 11:55 AM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Sent you a PM.
Old Oct 13, 2007 | 10:29 AM
RedLava's Avatar
Car: 86 z28
you got a pm
Old Oct 14, 2007 | 03:43 PM
JDHR7U's Avatar
Are parts still available and can you ship to Toronto Canada.
Old Oct 17, 2007 | 08:53 PM
catc's Avatar
Car: 1985 Trans Am
Engine: Chevrolet 355
Transmission: Borg Warner W.C. manual cog
Axle/Gears: B W 9-bolt 3.45 Limited Slip
Whats happening with this axle? Is it sold, complete ,parts?
Old Oct 18, 2007 | 05:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes, with the proper backing plates (as noted in the above link). I believe the plates are available from Ed Miller and/or AndyZ28. Here's a link that might be helpful if you choose to go that route:
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
