Engine, flywheels and other stuff
Engine: 360 .060 over TPI
I have a BUNCH of engine parts for sale- I have changed direction and looking to add to the NEW car fund! Stuff I have.
350 SBC 2-piece rear main seal forged crank, std/std- polished ready to go $250
350 SBC Eagle cast crank 1 piece rear main seal std/std new in box drilled throws $225
350 SBC Eagle cast crank 2 piece rear main seal std/std new in box drilled throws $225
Findanza aluminum flywheel for 1 piece rear main seal 153 tooth NEW $300
Findanza aluminum flywheel for 2 piece rear main seal 153 tooth NEW $300
14101128 Chevy Aluminum corvette heads stock, need rebuilding $300
USED Lakewood scatter shield for 3rd gen Camaro with hydraulic clutch and t-5 (tilted) or T-10 straight up $275
350 2 bot main, 2 piece rear seal block,.030 over all machine work done ready to assemble, hot tanked, new freeze pugs, ARP main studs, and new cam bearings etc $400
USED Kieth black Hyper pistons dished +0.030 hung on 5.7 rods that were rebuilt and have ARP rod bolts and balanced $150
USED Reconditioned 5.7 rods combo fo X and pink rods, ARP bolts low run time-$75
Edelbrock Performer intake manifold $60
M/T finned valve covers $40
Moroso valve covers- were gold, now wrinkle black $40
Steve
tel: 905-918-2633
Steve
tel: 905-918-2633
Re: Engine, flywheels and other stuff
more..........
All this stuff would make a REAL nice street engine,
I have gaskets, rings, bearings, cam hydraulic flat tappet and Cloyes timing chain, HV oil pump too.
I'll throw this in to someone who buys an "engine package form me" i.e block, heads, crank, pistons w/rods. etc. I could even assemble a complete motor for you too!!
thanks for looking Steve
Car: Pair of 92 Z28s
Hey im interested in:
Pretty much what the title says...i have a 2pc block that im putting a TKO 5 spd in. This is what i need correct?
Do you have a part# on it also?
Thanks.
Thanks.
it will work with the 10/5 in clutch and fit inside the stcok bellhousing. An 11" on a 164 tooth flywheel wont. fIDANZA PART NUMBER 198541 weight is 10.5 lbs.
Steve
Steve
BUMP TTT, make me some offers this stuff is collecting DUST!!!
thanks Steve
The 2pice ream Main seal Fidanza flywheel is SOLD
thanks Steve
bump I am open to offers!! great deals for a engine !package!!
I can even assemble it for you!!
Steve
Steve
hey,
want the 1 piece flywheel if you still have it. Can you do 280 shipped to 60516? Also interested in the aluminum heads if you can do a combo price ?
phone at 630-280-9472 - Jeff
or email jjanic2@uic.edu
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Can you give me the part number of the KB pistons?
KB101030 this is the part number form the summit web site. also they have the rods attached and have ARP rod bolts, the rods were reconditioned and then balanced. they have a approx. 20K miles on them.
The heads are not LT1 heads they are from a 85-86 Corvette, early GEN 1 SBC aluminum heads. 58 CC chambers. 1.94/1.60 valves.
I hope this helps
steve
KB142
KB Pistons
Chevrolet 350ci - 5.700" Rod - 18cc Dish
Product Description
• Bore Dia. 4.030"
• Stroke 3.480"
• Comp. Distance 1.561"
• Weight (Grams) 693
• 18cc D-Cup Dish
• Top Ring 5/64"
• 2nd Ring 5/64"
• Oil Ring 3/16"
COMPRESSION:
w/58cc Head: 9.6:1
w/62cc Head: 9.2:1
w/64cc Head: 9.1:1
w/76cc Head: 8.1:1
NOTES:
• Compression computed w/.030 oversize.
steve
KB142
KB Pistons
Product Description
• Bore Dia. 4.030"
• Stroke 3.480"
• 18cc D-Cup Dish
• Top Ring 5/64"
• 2nd Ring 5/64"
• Oil Ring 3/16"
COMPRESSION:
w/58cc Head: 9.6:1
w/62cc Head: 9.2:1
w/64cc Head: 9.1:1
w/76cc Head: 8.1:1
NOTES:
BlackphantomZ28
Aug 31, 2015 10:29 AM
