How much?
Old 01-10-2008, 07:15 PM
corvetteguy's Avatar
Car: 1986 Iroc Z
Engine: 5.0 TPI
How much?
How much is a 1989 350TPI and a THM700-R4 worth? The motor runs and the transmission fine.
corvetteguy is offline
Old 01-10-2008, 09:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: How much?
Depending on milage and condition, 500 to1500 for the pair.
8Mike9 is offline
Old 01-24-2008, 09:40 PM
Car: 1986 Iroc Z
Engine: 5.0 TPI
Re: How much?
Ok well it has 146,000 miles on the pair. Oh btw I am accepting offers on the pair or individuals.
Old 01-25-2008, 11:10 AM
89onlyZ51's Avatar
Car: 1987 Corvette Conv
Engine: Callaway Twin-Turbo
Transmission: Doug Nash 4+3
Axle/Gears: 3.07 Dana 44
Re: How much?
What car is the motor from? (f-body or vette?)
89onlyZ51 is offline
Old 01-28-2008, 10:09 PM
Car: 1986 Iroc Z
Engine: 5.0 TPI
Re: How much?
It came out of a 89 silverado.
Old 01-30-2008, 02:08 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: How much?
What did it come from originally? If it's the stock Silverado engine then it's not a 350 TPI and is a 350 TBI. This is way different than a 350 TPI and with that many miles you might have a hard time giving it away.
Darkshot is offline
Old 01-30-2008, 08:56 AM
Car: 1986 Iroc Z
Engine: 5.0 TPI
Re: How much?
I don't really know. A friend of mine ask me if I knew how I could get the word out. He was going to put it in a Firebird but he didn't have the time. for a project right now. I will have to ask him. What is Wrong with a TBI?
Old 01-30-2008, 06:08 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Re: How much?
There is nothing really "wrong" with TBI itself. They are just far more plentiful and cheap and less popular than TPI. They also got placed on very low performance engines from the factory. They also take a lot more work to feed a performance engine. A factory TBI engine (from a peformance standpoint) will have useless heads and a useless cam. The most valuable part about it is probably the block, which with that many miles is probably about ready to be stripped bare and rebuilt before it gets dropped into anybody's car.
Basically when you buy a TPI engine you're getting a complete TPI unit, decent heads, a cam that even if you're not re-using has some market value.
When you buy a TBI engine like you have it's going to need new heads (because the stock heads for that engine are low RPM swirl port torque heads, made for pulling boats and staying under 4000RPM), a new cam (same for the cam about low RPM), most likely a rebuild with that many miles, and either modification to the TBI unit to feed anything over 200hp or a different induction system. I have that exact motor in my thirdgen. It's a beast down low, nothing can beat me off the line and it's very good at spinning the tires. There is no such thing as top end though.
Darkshot is offline
Old 01-30-2008, 06:27 PM
Gen 3 Fbody Fan's Avatar
Car: 91 Trans Am, 88 GTA, 90 Formula 350
Engine: 305TPI, 350TPI, 350TPI
Transmission: 700R-4
Axle/Gears: 3.27, 3.27, 3.23
Re: How much?
Just a note I know in the 1990 2500 the 350 is a non-roller block, so that motor if it is a TBI motor from a Silverado may not even have a roller cam
Gen 3 Fbody Fan is offline
