parting a 91 firebird
Old Feb 12, 2008 | 11:43 AM
intruder's Avatar
it has a tpi 5.7 but the motor is shot
Old Feb 12, 2008 | 11:55 AM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Re: parting a 91 firebird
Thats a nice bird. Looks to be in very nice shape. If you don't mind me asking, why are you parting it out?
Old Feb 12, 2008 | 11:58 AM
intruder's Avatar
that's what i thought, it has some rust in the floors so it.s better off parted
all gfx's are excellent, from and rear bumper's are perfect, tpi
Old Feb 12, 2008 | 12:34 PM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
How much for the cupholders from the door panels?
Old Feb 12, 2008 | 01:25 PM
intruder's Avatar
they are missing didn't have them when i got it
Old Feb 12, 2008 | 01:37 PM
87_355ci_Camaro's Avatar
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
any rust on the rear fender wells??? Kinda need the inner metal as a skin to weld over my temporary fix on my car. Take some pics of the floors and motor area. Car might be salvageable alittle rust is nothing to the right person that knows how to fix it.
Old Feb 12, 2008 | 01:44 PM
intruder's Avatar
i,m not going to the trouble to cut any body part's off..
Old Feb 12, 2008 | 02:29 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Would you sell me the two black plastic pieces that go under the front Nose GFX? They are almost like a scoop thing that go on the underside of each side of the front nose Piece. It's hard to explain.
Old Feb 12, 2008 | 03:30 PM
bonesbrakr's Avatar
How much for the upper plenum with MAP bracket and sensor??? stock runners???
Bill
Old Feb 12, 2008 | 05:15 PM
intruder's Avatar
the the motor is a 87 out of a camaro i put a speed density harness on it, so the plenum is still a maf plenum and it has the cold start injector,
Old Feb 12, 2008 | 06:20 PM
Steve86TA's Avatar
Car: To many to list
pm sent
Old Feb 12, 2008 | 07:16 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
How much for the front clip shipped to a comercial address: 15229 pittsburgh PA.
Old Feb 12, 2008 | 07:26 PM
hutchmike's Avatar
Want a title? Post!
How much for fuel sender and pump? If pump is bad is ok just need sender with uncut lines with connections
Oh how about throttle cable? Needing tuned port cable for lt1 convert.
Old Feb 12, 2008 | 10:07 PM
IrocZ85's Avatar
Why did the ebay auction end and what would you want for the whole car, LMK if not I mostly need the ECM
Old Feb 14, 2008 | 01:29 PM
intruder's Avatar
ttt
Old Feb 14, 2008 | 01:32 PM
Shift06's Avatar
Well????
Old Feb 14, 2008 | 01:34 PM
intruder's Avatar
i would but i won't ship to canada, to much trouble the last time
Old Feb 14, 2008 | 04:56 PM
MiTHRiL's Avatar
Car: 93 TA, 92 GTA, 91 TA
Engine: LT1, L98
Transmission: T-56, 700R4
Axle/Gears: 3:23
PM sent
Old Feb 14, 2008 | 11:06 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Are the front ground effects still available? If so, how much to area code 41005.
Thanks!
Old Feb 15, 2008 | 12:38 AM
larry88ttops's Avatar
Car: 1988 Camaro w/T Tops
Engine: 305 TBI
Transmission: Borg-Warner 5 spd
Do you know if the horns work? Do you still have them? If so, then how much would they be shipped to 80129 in Littleton, CO? Thanks.
Old Feb 15, 2008 | 10:57 AM
91 maro convert's Avatar
Car: 91 Camaro RS Covertible
Engine: 383 stocker TPI
Axle/Gears: 3.73 posi
how much for the TPI setup with harness?
Old Feb 15, 2008 | 10:28 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
How much for the A/C box (engine bay side) shipped to 78640?
Old Feb 15, 2008 | 10:36 PM
raycruz383@nets's Avatar
How Much for the Left and right front gfx shipped to 33917.
I want them let me know how much raycruz383aol.com
thanks thanks Ray
Old Feb 16, 2008 | 07:39 AM
intruder's Avatar
sale pending on the car as a whole
Old Feb 17, 2008 | 01:34 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
T-tops? The picture isn't working right now.
Old Feb 17, 2008 | 02:19 PM
intruder's Avatar
read my last post
Old Feb 20, 2008 | 05:29 AM
intruder's Avatar
the car is sold !!!!!!!
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
