1988 tpi setup
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
1988 tpi setup
Its from an 88, was going to switch it out with my tpi but decided Im going to go with a stealth ram or carb. anyway it includes the throttle body,upper plenum(slightly ported),runners, lower manifold, fuel rails and injectors( injectors read fine for ohms but may be no good got from a friend over 200k on them) computer,maf( screens deleted) and the tube and box that the maf connect to. $300. thanks
Car: 87 GTA
Engine: 385 sbc
Re: 1988 tpi setup
Justgot home from installing my new trans
...its been an exciting saturday...Im by midway airport. Ill sell just the computer for $50 .thanks
...its been an exciting saturday...Im by midway airport. Ill sell just the computer for $50 .thanks Member
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: 1988 tpi setup
Would you be willing to sell just the lower manifold, runners, plenum and fuel rails? If so, how much shipped to 32708? Looks beautiful by the way. Thanks.
Car: 87 GTA
Engine: 385 sbc
Re: 1988 tpi setup
bumpstigity.. air dams ground down and smoothed around runner and throttle body ports
Car: 87 GTA
Engine: 385 sbc
Re: 1988 tpi setup
I think it would be about $44 Im guessing its about 30lbs for everything.thanks
Car: 2007 Cobalt LT
Engine: M62'd 2.2L L61
Transmission: 4T45E 4-speed Automatic
Axle/Gears: Stock
Re: 1988 tpi setup
Do you still have any of the original lines for that intake?
Perhaps like the PCV breather line setup (from passenger valve cover to the throttle body)?
Car: 1991 RS t-tops
Engine: 305 tbi / 350 in the works
Transmission: 700R4 built buy dyno don
Re: 1988 tpi setup
is this still available, i am working on a new motor for my rs, if so how much and lets talk.
rick 714-390-5047
rick 714-390-5047
Car: 87 GTA
Engine: 385 sbc
Re: 1988 tpi setup
SUNDAY,SUNDAY,SUNDAY ONLY..........just kidding,$270 plus shipping. or possible trades considerd
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: 1988 tpi setup
I just wanted the plenum. If I came to your house and picked it up, how much would you let it go for? My plenum has a crack in it and leaks on my 86. The rest of my tpi system is ok. Let me know how much cause I'm in Des Plaines, basically, your back yard!
Car: Firechicken
Re: 1988 tpi setup
alright, good luck with the sale. Hope you get her sold but if you don't PM me and we maybe able to work something out.
Car: 70camaro rs/ss, 83 camaro
Engine: 70 has 454, 83 has 327
Transmission: both have 700r4
Axle/Gears: 70 has 3.73, 83 has 3.27
Re: 1988 tpi setup
pm sent!! I have cash please call.. Thanks Ted.
Sanjay
Aug 12, 2015 03:41 PM
