TPI Conversion/Swap Parts, Complete
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
TPI Conversion / Swap parts.
Should be everything you need to convert to TPI;
distributor
plenum
runners
throttle body
lower intake manifold
fuel rail & injectors
wiring harness
computer & eprom
I got this in a package deal, was told it was pulled from a running '89 Firebird 350 Auto. It has a cold start injector so its definatly pre '89. The red rattlecan paint is ugly, there is some dings on the runners, and this setup is probably missing some nuts and bolts, but otherwise should be complete.
Yes, its ugly so it is priced accordingly. $250 OBO + Shipping
distributor
plenum
runners
throttle body
wiring harness
computer & eprom
Car: 91 Chevy Camaro
Engine: 5.7L 440hp 450FBT
Transmission: WC T-5
Axle/Gears: 3.73 Rear end
Re: TPI Conversion/Swap Parts, Complete
i will give you 225 right now.
can you send me some picture of everything else.
Opha - its been a while since I've inspected the harness, but if I recall correctly there were two cuts that appear to have been repaired using duct tape (not my work).
syncom - you have a pm
ttt
IS that the harness that hooks up to the transmission. IF so what type of tranny does it hook up to.
I don't think the tranny harness is on there but it may be, should be for a 700r4. I don't think I have a waterneck, but I'll double check.
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
looks like a 86 setup. i have an 86 camaro and an 88 camaro. the 86 has that hei style distributor, my 88 has an electronic small cap external coil distributor. just trying to help out idk if my info is right i am just basing my guess off personal expirience with my car.
i have some stuff coming in the mail from brisk, ill post up when they get here, so far he has been a great seller. thumbs up
Car: 87 Trans Am GTA
Engine: 5.7L TPI
I'd like to sell as a package, thanks.
$225 OBO
$200 OBO
morning bump
weekend bump
parts went to landfill
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Wow didn't even sell it for aluminum or copper scrap. Rip tpi
Terrell351
Jun 13, 2021 01:13 PM
Sanjay
Aug 12, 2015 03:41 PM
