2 bolt 350, 85-90 gfx, American racing wheels, 6-point roll cage, more ....
Car: 82 Trans am
Engine: Twin turbo 350
Re: 2 bolt 350, 85-90 gfx, American racing wheels, 6-point roll cage, more ....
I will take offers on all of this. Name your price!
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
How much shipped and paypaled for the chrome tips to NY 11214?
Car: 82 Trans am
I emailed you on the Bumper Cover...
Need shipping quote to 13219 (Syracuse NY). Also, how far are you from Buffalo NY?
Car: 82 Trans am
Car: 82 Trans am
This is all still available!
I realized the cage is an 8 point, not a 6 point.
Make offers on anything!!
All prices are OBO. Please take into account shipping with your offer. Items that are able to ship will leave from zip 44143.
Contact me at jeff.fabien@gmail.com with any questions, offers, or if you want better pictures.
350, 2 bolt main. 1 piece rear main seal. Came out of a truck. Should make a good core. Or i guess you could slap it together and try and run it?
$150
Everything
882 Heads
Piston
Piston pn
Rods
Deck surface
Heads
Block casting number
1 pc rear main seal
Cylinder Wall
350 casting
2 Bolt mains
Underside
S&W Racecars 8 point roll cage. This is a weld-in, cut to fit cage. Some assembly required. It sat outside for a bit and got a little rustly. Its 100% structurally sound. I used some rust converter on it and thats the funny looking scale you see. It cleans up pretty easily with a wire wheel. The mounting plates were also rusty but it was easier to have new ones made up out of 1/4" mild steel.
$125
Cage 1
Cage 2
Cage 3
Cage 4
American Racing chrome wheels and Cooper Cobra* tires. Proper offset for a thirdgen. These are 15 or 16 inch - I will check on the size and tire size later today. One tire was replaced with another brand, but the style and location of the text is very similar. I have chrome Gorilla locking lug nuts and the center caps for these.
$200
Wheels 1
Wheels 2
Wheels 3
Wheels 4
LT1 oil pump drive for distributorless operation. Was going to use this but ended up getting a nice billet piece from Holley that would plug the dist. hole as well.
$20 ?
Lt1 oil pump drive
28 Spline axle from a 4th gen rear. Bought a pair to replace one bent axle and didnt need the other. Some surface rust that should clean up with some emery cloth.
$30 ?
Axle
28 Spline
Bearing surface
Front
Two 1g DSM (90-93(?) talon, eclipse) intercoolers. One is in perfect shape, the other has some pitting on one pipe. The previous owner put a little silicone under the rubber connector. Both held pressure fine. If nothing else, these make great cores.
$30 each
Front
Back
Core 1
Core 2
Pitted outlet
85-90 Trans am Ground effects. Decided against putting these on my 82. They are in good shape and have all the hardware included.
$250 for all
Fronts
Backs
Hardware
85-90 Trans am bumper/nose assembly. Paint looks like it was in a little fender bender, but the nose is totally straight - check out the profile view. One marker light is cracked, one is fine. Comes with the steel bumper and plastic crush material.
$100
Nose 1
Nose 2
Marker light 1
Marker light 2
Nose back
Chrome exhaust tips from a holley catback. Each is 3" inlet to dual 3" outlet. I just didnt like the way they looked.
$30
Exhaust tips 1
Exhaust tips 2
Exhaust tips 3
Now, some non-thirdgen related stuff:
$7 each
USB A to USB mini-B cord. Your camera probably uses one like this. I have eight unopened for a project that never went through.
USB cord
Fender BXR-25 Amp. Pretty decent little unit, I used it with the bass below. Effects loop and headphone jack. Great for jamming at home or in a studio.
$150
Fender BXR-25 1
Fender BXR-25 2
Fender BXR-25 3
Ibanez bass. Not sure what the details of it are, its a pretty simple 4 string. Never had much issue with buzz on it even as a beginner. It is not strung, but I can throw some strings on there for you if you like. Comes with a soft case gig bag, and i can throw in a strap and a 25 foot monster cable with the bass or the amp.
$120
Bass 1
Bass 2
Bass 3
Bass 4
Bass 5
Bass 6
Bass 7
Daewoo TV. Its really basic, but it does what it needs to do. Limited inputs on the back, so make sure it does what you want. Comes with working remote and good picture.
$40
TV 1
TV 2
TV 3
TV 4
$150
Everything
882 Heads
Piston
Piston pn
Rods
Deck surface
Heads
1 pc rear main seal
Cylinder Wall
350 casting
2 Bolt mains
Underside
$125
Cage 1
Cage 2
Cage 3
Cage 4
$200
Wheels 1
Wheels 2
Wheels 3
Wheels 4
$20 ?
Lt1 oil pump drive
$30 ?
Axle
28 Spline
Bearing surface
Front
$30 each
Front
Back
Core 1
Core 2
Pitted outlet
$250 for all
Fronts
Backs
Hardware
$100
Nose 1
Nose 2
Marker light 1
Marker light 2
Nose back
$30
Exhaust tips 1
Exhaust tips 2
Exhaust tips 3
$7 each
USB cord
$150
Fender BXR-25 1
Fender BXR-25 2
Fender BXR-25 3
$120
Bass 1
Bass 2
Bass 3
Bass 4
Bass 5
Bass 6
Bass 7
$40
TV 1
TV 2
TV 3
TV 4
Car: '88 IROC-Z
Engine: 383 Stroker
Im interested in the cage. Can you get a shipping quote to 28540?
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
pm sent on 350.
Car: 82 Trans am
Shipping is going to be ridiculous. Probably upwards of $100. I think the price new from S&W was just over 200. The hoop is about 6' by 5'.
Replied.
Its all still available, people. Make offers if you like - it needs to go.
Replied.
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
where are you in ohio? i might possibly be going to fostoria to pick up a car, and would be interested in teh cage possibly.
Car: 82 Trans am
Shipping on Cage to Toronto, Ontario, Canada M1K 2T8?
Also, if the tips are not sold, I'll take those too.
Car: 1987 Trans Am GTA
Transmission: 5 Speed
How much for the driver side rocker ground effect?
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
Do you still have the wheels for sale?
Car: 82 Trans am
I'll be in cincinnati next weekend how much do you want for the ground effects with out the bumpers?
Car: 82 Trans am
$150 on the ground effects minus the bumpers?
I'm in cleveland. You do know that its a good 5 hr drive from cinci, right? Just checkin ...
Car: 82 Trans am
Shipping is going to be huge ... I'm not even sure how to send something like this. Its 100+ lbs. Truck freight maybe?
I could probably meet you halfway in columbus or something one weekend when I visit family down there...
What'd the wheels end up being 15" or 16"?
Car: 88 Camaro
Engine: 350, 5.7, TBI
this will be my first engine job so excuse stupid questions... will the 350 fit in a 305 88 camaro? and would i need to get anything else to swap it?
how much to ship to 42211?
i really need a block and so far your the closest
