Complete TPI setup of 350 iroc
Old May 13, 2008 | 06:08 AM
85camarojunkie's Avatar
Car: Camaro coupe
as is in title. complete fuel injection setup off 350 iroc. fits all small block chevys. whole tuned port, computer, wiring.
email k.reed19@insightbb.com
859-307-6588
KEVIN
Old May 13, 2008 | 07:44 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
Re: Complete TPI setup of 350 iroc
price?
Old May 13, 2008 | 11:03 PM
Car: Camaro coupe
300 OBO
Old May 14, 2008 | 09:40 AM
kevinm_92's Avatar
Car: 92 RS, 92 Z28
Engine: 305, 305
Transmission: 5SP, 700r4
Hey I'm in Northern Ky also, I just started looking into tpi, would this setup fit on a 92, 305?
Old May 14, 2008 | 09:43 AM
Car: Camaro coupe
Depending on the block if its a 92 Im not sure.. I think this model only fits pre-88 year chevys. Unless you have a swaped motor. Also is yours a vortec that might be different to. let me know what you have
Old May 14, 2008 | 09:50 AM
kevinm_92's Avatar
Car: 92 RS, 92 Z28
Engine: 305, 305
engine looks like a stock 305 engine with tbi - car looks like a z28 but I'm pretty sure it isn't because I can't think of why someone would swap out the tpi for tbi
Old May 14, 2008 | 09:53 AM
Car: Camaro coupe
well most 91-92 camaros came with TBI. the TPI only lasted a few years. but if you would like i will meet you somewere when your ready for purchase. I live 5 minutes from bellevue...
Old May 14, 2008 | 09:56 AM
kevinm_92's Avatar
Car: 92 RS, 92 Z28
Engine: 305, 305
I gotta try to get more info on whether this is compatible, I'll let you know if I find out that it will work.
Old May 14, 2008 | 10:02 AM
Car: Camaro coupe
well i just looked it up. And from what i can see is the only difference would be if it was VORTEC. and since its an RS then i highly doubt that it is a vortec. So it will fit
Old May 14, 2008 | 10:14 AM
kevinm_92's Avatar
Car: 92 RS, 92 Z28
Engine: 305, 305
What does VORTEC refer to? I have heard of vortec engines in chevy blazers, but not camaro's. Am i thinking of something totally different?
Also I have read a little and it seems that the intake on an 85 and a 92 were different, something to do with the bolt locations? Have you ever heard of this?
Sorry I'm asking all these questions I just don't want to spend the money on a part that will need modified to fit.
Old May 14, 2008 | 10:17 AM
Car: Camaro coupe
Look at the intake bolts and see if they're all at the same angle. The 4 corner bolts area at a 45degree angle and the 2 center bolts on each side are at a 90 degree angle or straight up. or send me a picture of it ill tell ya.
Old May 14, 2008 | 10:32 AM
Car: Camaro coupe
this will work for all blocks even your vortec. I will show ya pics of the procedure only take 5 minutes. let me know tonight. i pm'd you my number
Old May 14, 2008 | 10:33 AM
FirenScuba's Avatar
Car: 1988 Camaro
Engine: V8 305
Transmission: 700r4 auto
you got any pics?
Old May 14, 2008 | 10:38 AM
Car: Camaro coupe
not just yet but its all there. It is unbolted. You have to install these piece by piece.
TO ALL, FUEL PUMP will be included
Last edited by 85camarojunkie; May 14, 2008 at 10:47 AM. Reason: Im an idiot and cant do things right the first time
Old May 14, 2008 | 11:25 AM
FirenScuba's Avatar
Car: 1988 Camaro
Engine: V8 305
once you get some pics let me know asap im very interested and will mostly likely buy it
Old May 14, 2008 | 12:59 PM
Car: Camaro coupe
ok. and shipping is not included. I shipped one out last year costed about 110 im pretty sure. Ill get a queote if youd like. what is ZIP
Old May 14, 2008 | 03:07 PM
FirenScuba's Avatar
Car: 1988 Camaro
Engine: V8 305
11003
Old May 14, 2008 | 07:56 PM
Car: Camaro coupe
Not sure off the top of my head ill check it out in morning. any other parts you need for cars. ANYONE> i have an iroc being parted out
Old May 14, 2008 | 10:33 PM
FirenScuba's Avatar
Car: 1988 Camaro
Engine: V8 305
im looking for a fog light grille if you got or a really clean set of front bumper turn signals
Old May 14, 2008 | 10:59 PM
Car: Camaro coupe
got them both. Ill get pics..
Old May 15, 2008 | 11:51 AM
Car: Camaro coupe
Sorry forgot pics of wiring and computer but distributer is also included.
I will pressure wash it before i ship
Who wants it
Attached Thumbnails Complete TPI setup of 350 iroc-104_0668.jpg   Complete TPI setup of 350 iroc-104_0666.jpg   Complete TPI setup of 350 iroc-104_0667.jpg
Old May 15, 2008 | 04:54 PM
FirenScuba's Avatar
Car: 1988 Camaro
Engine: V8 305
all this after a quick cleanup should be all ready to go right?
Old May 15, 2008 | 08:17 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Just to clear a few things up. A tpi setup will NOT bolt to vortec heads unless you buy the correct base. As far as what vortec refers to: vortec is GM's name for its line of truck engines which starting in the mid 90's. Some people swap to vortec heads as they are great flowing heads for factory castings and can be had fairly cheap, they require a special intake however. Vortec engines or heads never came factory on ANY car let alone a 3rd gen f-body. You are right TPI was only available a few years, those years are 1985-1992 as far as f-bodies are concerned. Your TPI setup will fit his 92 but he will need to reangle a few bolt holes with a drill in the base intake, not that hard.
Old May 15, 2008 | 11:08 PM
Car: Camaro coupe
Thanks for clearing that up i knew it bolted up but i completely forgot about the VORTEC being different.
Is anyone interested or not. AGAIN heres what i have to go wtih it distributor, wiring, all intake complete with injectors and fuel supply sensors and anything else let me know. If any quesions pm me or k.reed19@insightbb.com
Old May 17, 2008 | 07:39 AM
Car: Camaro coupe
THANKS FOR QUICK RESPONSE TO ALL...... SOLD
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
