FS (again) aluminum L98 corvette heads (113's)
Old May 21, 2008 | 01:03 PM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
My first buyer can't come up with the money, so these are available again.
I bought some Trick Flow heads for my Corvette, so my stockers are for sale. They are bone stock aluminum heads from a 91 Corvette. 61,000 miles on them. 58 CC combustion chamber.
$400 with stock valve springs, or for another $50 I'll put some LT4 springs on them.
Casting number is 10088113.
The heads are available complete from GM under GM part number 12556463. Here's the description from GMPP:
Part#: 12556463
Desc: Corvette Design for 350 HO service engine
Casting: 10088113
Material: Aluminum
Intake Runner Volume (cc): 163
Combustion Chamber Volume (cc): 58
Valve Diameter: I: 1.94" E: 1.50" D" port exhaust
Spark Plugs: Angled
Heater riders: No
This aluminum cylinder head assembly for small-block Chevrolet V8s is ideal for street rods, fresh-water power boats, and high-performance applications. GM Performance Parts' aluminum cylinder head assembly combines the benefits of light weight, advanced design, and an affordable price.
This complete head assembly includes valves, chrome silicon heavy-duty valve springs, retainers, 3/8" screw-in rocker studs-everything an enthusiast wants in a high-performance cylinder head package! GM Performance Parts aluminum cylinder head assemblies are based on brand new Corvette light alloy castings (P/N 10088113).
The Corvette cylinder head's advanced design features include D-shaped exhaust ports that enhance the flow of burned gases, high-velocity intake runners that provide crisp throttle response, and centrally located spark plugs that improve combustion efficiency. Valve seat inserts for 1.94" diameter intake valves and 1.50" exhausts are installed in the 58cc combustion chambers.
Raised rocker cover rails with machined sealing surfaces virtually eliminate rocker cover gasket oil leaks. This high-performance cylinder head assembly is used exclusively on High Output 5.7-liter small-block V8 engines. Unlike production Corvette cylinder heads, it is outfitted with special heavy-duty valve springs (see part number 12551483 for technical specifications).
A pair of aluminum cylinder heads offers a weight savings of approximately 50 pounds over comparable cast iron cylinder heads. (A bare aluminum casting, less valves and springs, weighs 19 pounds, versus 44 pounds for a bare cast iron head). This reduction in total engine weight of 25 pounds each can improve handling, acceleration, and fuel economy.
Part Number...Description
12555269.........Stamped steel rocker cover
10229162.........Corvette screw-in oil filter cap
12342056.........Chrome screw-in oil cap w/GM logo
12338092.........Valve cover hold-down bolts (8 required)
14094717.........Hold-down bolt washers (8 required)
14088793.........Hold-down bolt gaskets (8 required)
14088564.........Neoprene rocker cover gasket
12557236.........Composition head gasket, .051" thick
12495499.........Head Bolt Kit
12495490.........Rocker Arm Kit
Technical Notes: This casting does not have intake manifold heat riser or EGR passages. The spark plug holes are angled; check for adequate exhaust manifold or header clearance. Use 3/4" reach gasketed spark plugs with 5/8" hex heads (AC FR5LS), 904, or MR 43LTS. In rapid fire use #8 plug. Both ends of the head are machined for alternator, power steering, and air conditioning compressor mounts. No pushrod guideplates; use rail type rocker arms P/N 10089648. This aluminum head assembly requires valve covers with central hold-down bolts and extra-long bolts with washers. A composition head gasket with stainless steel fire rings is recommended to prevent galvanic action between the head and a cast iron engine block. This head assembly is the same as P/N 10185087, except valve spring and retainer change.
The only thing I noticed is that I'll include the factory guide plates, unlike the new GM heads.
Old May 21, 2008 | 01:30 PM
dv8's Avatar
dv8
Car: 88 IrocZ Vert
Engine: 5.0 TPI
Re: FS (again) aluminum L98 corvette heads (113's)
I'm interested..are they still 400?? Shipping to 80233.
Last edited by dv8; May 21, 2008 at 01:35 PM. Reason: found info from previos post
Old May 21, 2008 | 01:31 PM
maj75's Avatar
Car: 1983 Mecham MSE Trans Am
Axle/Gears: 10 bolt Posi, 3.something
How much?
Old May 21, 2008 | 10:09 PM
neat's Avatar
Car: 1991 Corvette
Doh, forgot the price. First post is edited, but I want $400 for them with the stock springs, and $450 with the LT4 spring upgrade.
Old May 23, 2008 | 12:43 PM
neat's Avatar
Car: 1991 Corvette
Bump.
Old May 23, 2008 | 04:36 PM
irockwithdirt's Avatar
how much to ship to 62240? Thanks!
Old May 23, 2008 | 10:14 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
damn I should pick these up for my '91... shipping quote to 99114 please.
Old May 25, 2008 | 09:26 PM
neat's Avatar
Car: 1991 Corvette
Still for sale.
Old May 27, 2008 | 06:50 AM
gmtofd's Avatar
I could use the springs for my 113 heads.
Would you break them out?
Old May 27, 2008 | 12:52 PM
neat's Avatar
Car: 1991 Corvette
I'll sell you the stock springs if you want.
Old May 28, 2008 | 06:06 PM
neat's Avatar
Car: 1991 Corvette
To the top.
Old Jul 5, 2008 | 08:18 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
are these heads stil for sale just checking
Old Jul 6, 2008 | 12:51 AM
neat's Avatar
Car: 1991 Corvette
Sold.
lt500r55
Sep 1, 2021 01:30 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chiknhawk
Aug 23, 2015 05:54 PM
