Kirban Fuel Pressure Regulator #6547 (new)
Old 06-16-2008, 06:28 PM
89Kicker_IROC-Z's Avatar
Car: 89' IROC-Z
Engine: HSR B2L 350ci w/LT4 hotcam and AFR 195's
Transmission: Transgo'd 700R w/Yank 2800
Axle/Gears: 9 Bolt, 3.45
I have a brand new billet afpr by kirban which is model #6547. I bought it to replace the junky holley unit that came with my stealthram but It wouldnt clear my tall style valve covers. Works with holley/aftermarket fuel rails and standard non-tall valve covers. Comes with instructions. $105 and ill cover shipping. Last I heard these were on backorder on 6/14. pics tonight
Old 06-16-2008, 09:05 PM
Car: 89' IROC-Z
Re: Kirban Fuel Pressure Regulator #6547 (new)
Old 04-20-2010, 10:20 AM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Do you have any problems with clearance for the regulator with tall valve covers? Because I read something from someone, and they said they have a clearance issue with the regulator hitting the valve cover. I have roller rockers, so I can't lose the tall valve covers. Let me know.
Old 04-20-2010, 06:32 PM
Car: 89' IROC-Z
Yes the kirban unit will hit tall style valve covers...this is why I sold it to begin with.
I sold it a few days after posting
Steve
Old 11-06-2011, 10:09 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hey I know this is a really old thread but I am looking into the Kirban unit. I'm guessing it only hits tall VC's if you install it backwards, and that if you aim the adjuster screw inwards that it doesn't take up any more space than a stock reg?
Old 08-26-2015, 07:40 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Can anyone confirm this?
Old 08-26-2015, 07:53 PM
Car: 2000 BMW M5
The Kirban 6547 fits a Stealth Ram using tall, billet valve covers, if you orient the FPR such that the vacuum line and adjusting screw face inward. I can confirm I did this.
Old 08-26-2015, 08:09 PM
Car: 92 1500p\u 2wd
Perfect that's what I needed to know cus I just ordered one and have tall valve covers! What fitting do I need to hook to my -6an fuel line?
Old 08-26-2015, 08:10 PM
Car: 2000 BMW M5
The fitting Holley included that was a 90 deg elbow that went from straight metric thread w/ an o ring seat to -6 fit this regulator too. Look at the previous post dates...its been a long time since I had that setup!!
Old 08-27-2015, 01:17 AM
Car: 92 1500p\u 2wd
Yea I see it's old....been searching the forum trying to figure out what I need for fitting for this HSR fuel rail. The HSR was used and never came with the hard line the connects the front of the rails together. I'd like to use the extra braided -6an line I have but need the fittings to do so. So for this afpr I need a straight metric thread w/ an o ring seat to -6 fitting?
Old 08-27-2015, 08:59 AM
Car: 2000 BMW M5
I found it. You need a 90 degree 14mm x 1.5 to -06AN. The 14x1.5 end should have an adjustable fitting with a nut so you can clock it. This type of fitting is what you want
http://www.discounthydraulichose.com...m?1=1&CartID=0
So you'd want
9069-06-14 9069-06-14 | 3/8" JIC Male x M14x1.5 Metric Male Adj. 90°
$11.06
$10.40
3/8" 37 deg is the same thing as -6AN
MustangBeater20
10-29-2022 09:20 PM
9192camaro
16
02-03-2019 12:21 AM
wayshegoes
08-17-2015 12:00 PM
89-S-dime
08-12-2015 11:57 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: Kirban Fuel Pressure Regulator #6547 (new)
