parting out a 350
Old Jul 22, 2008 | 09:25 PM
91camaroRSx383's Avatar
Car: 91 Camaro RS
Engine: 383 Stroker
Transmission: T5 Wolrd Class
Axle/Gears: Open 3.27 gears
parting out a 350
ive got just about everything for a stock pre87 350. just PM me if you've got questions
Old Jul 22, 2008 | 09:57 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Re: parting out a 350
u got some pics of wat u have
Old Jul 23, 2008 | 07:45 AM
Car: 91 Camaro RS
Engine: 383 Stroker
no not currently, i have a feul pump, heads, crank, pistons(some have some abrasive marks on the tops), timing chain and sprocket, cam, lifters, crank gear, rocker arms, push rods, timing chain cover, oil pan, oil pump, exhaust manifolds, valve covers, every bolt you need, and even the spark plugs if you want em.
Old Jul 23, 2008 | 03:15 PM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
Where are you located ?
Old Jul 23, 2008 | 03:19 PM
Car: 91 Camaro RS
Engine: 383 Stroker
South Carolina just under Charlotte NC
Old Jul 28, 2008 | 10:49 PM
marcus88's Avatar
Car: 87 GTA
Transmission: Automatics
PM'd
Old Jul 29, 2008 | 10:59 AM
Car: 91 Camaro RS
Engine: 383 Stroker
Pictures sent marcus
Old Jul 31, 2008 | 09:24 PM
fastregalwe2's Avatar
got a good set of rods???
Old Jul 31, 2008 | 09:43 PM
Car: 91 Camaro RS
Engine: 383 Stroker
push rods or piston rods
Old Jul 31, 2008 | 10:01 PM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
Casting numbers for the heads?
Old Jul 31, 2008 | 11:29 PM
F-Body_Fetish's Avatar
Car: 1984 Camaro Z/28
Engine: 350 SBC
Would you happen to have the accessories? maybe a starter? flywheel if i'm lucky?
Old Aug 1, 2008 | 08:28 AM
Car: 91 Camaro RS
Engine: 383 Stroker
Mark the casting number is either 3888888 or 3888838
nah man sorry all ive got is the stuff that came off of the block or out of the block, ive got a feul pump though thats about as close to not on the block as it gets
Last edited by 91camaroRSx383; Aug 1, 2008 at 08:29 AM. Reason: Automerged Doublepost
Jake_92RS
Jan 28, 2020 10:37 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
st.evel07
Aug 13, 2015 06:15 PM
1nastygta
Aug 8, 2015 07:38 PM
