Parting out 12 sec TPI-T56 Combo
Car: 89 IROC 5.7
Engine: 357
Descreened MAF
Airfoil
TPIS 58mm TB
K&N Air Filters
24 lb/hr Fuel injectors
TPIS Bigmouth Intake Manifold
SLP High flow intake runners
3rd gen Edelbrock TES ceramic coated headers w/air & Ypipe
4th Gen Borla Adj. 3” Catback exhaust (stainless steel)
T-56 Tranny swap from 94 Camaro SS
Aluminum Slave cyl.
Mcleod Clutch Disc
LT1 11” Pressure plate
Yukon 3.73 Ratio Rear End Gears
Steel Driveshaft
Centerforce 2 piece RMS Flywheel for t56 conversion.
Spohn crossmember for t56 conversion
Hurst Sidewinder shift ****
Ws6store short stick
(prefer engine to sell as complete setup)
Has gone 12.87 @ 106 with TPI setup @ 3600 lbs
Hypereutectic Flat-top pistons
Corvette L98 Hyd. Roller Cam
Trick Flow Twisted Wedge Aluminum Heads(1.5 Int. 1.94 exh.)
Crowler 1.6 Roller Rockerarms
Roller lifters
Stock cast crank (350)
4 bolt main – 2 piece rms bored .040 over. Block
Brand new A/c Compressor
Fixed tachometer for 3rd gen camaro (145mph gauges) everything works.
q-power 4x6 front speakers. (brand new and kinda hard to find the size)
6x9 pioneer speakers (model will be posted if interest is shown or when pulled out)
Power drivers seat (torn in 1 section) – IROC seat - gray
Passenger IROC seat – mint – gray
Passenger seats & fold down backing – gray – mint
Recently replaced rear hatch pull down.
Grant steering wheel.
Hypertech chip for 89 camaro 350 automatic
This is a daily driven car that I am parting out so please ask for small things that are not listed.
Email will reach me fastest – Lozercoward@hotmail.com
I will check the forums periodically to update items accordingly
Please send a offer with each item you want. I can provide details on everything since i built it.
Airfoil
TPIS 58mm TB
K&N Air Filters
Aluminum Slave cyl.
Mcleod Clutch Disc
Steel Driveshaft
Roller lifters
Car: '92 Z28 25th anniversary/ '89 RS
Engine: 400 sbc
Axle/Gears: moser 12 bolt w/4.10
Re: Parting out 12 sec TPI-T56 Combo
do you have the fuel rails? with or with out 9th injector?
Car: 1992 Firebird
Transmission: 700R4 with B&M shift kit
Axle/Gears: 3.23 zexel 4th gen
would you be willing to sell the y-pipe by itself, or do you want to sell it with the headers only?
Car: 1987 Iroc
Engine: 502
Axle/Gears: Ford 9" 3.73
Do you still have the Centerforce 2 piece RMS Flywheel for t56 conversion for sale? Is this the steel or aluminum flywheel? Do you know if this will work with a Spec (I think stage 3) clutch and PP. You can email me at bbut2@osceola.org
Car: 91 convertible, 89 TTA, 03 GT2
Engine: 5.0 TBI, 3.8 Turbo, 3.6 Twin Turbo
Transmission: 700r4, 2004r, 6 Speed
Axle/Gears: 2.73, 3.27
pics and price for the steering wheel?
Car: CAMARO
Engine: 383 LT1
Transmission: T 56
do you have an adjustible fuel pressure regulator.. if so how much for it shipped to 70124
Car: 87 iroc
Engine: 5.7 ZZ4, AFR, Stealth Ram, Comp cam
Transmission: 1993 T56 viper internals w Spec3+
Axle/Gears: moser 9" truetrac 3:89
how much for the 58mm tb.
Pm me a price for the engine and trans together. I'm in houston and could possibly use the whole setup.
Not sure how old this listing is... maybe august?
Car: 1985 Yellow Iroc Z w/LS interiors
Engine: 305ci 5.0L
Car: 91 RS and 89 RS, 99 Tacoma TRD
Engine: 91-L03, 89-350 TBI
Transmission: 91-700r4, 89-T5
I am interested in both the engine and trans. What price range are we looking at?
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Wondering if you still have the headers and ypipe? Thanks!
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I sent him a PM the other day with no response and it's an old post....
LT1Formula
20
Nov 14, 2015 12:02 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
12, 406, baton, camaro, conversion, corvette, firebird, lozercoward, rouge, sec, shifter, sidewinder, t56, tpi, transmission
