ProBuilt 700r4 0 miles and new edge converter
Old Sep 23, 2008 | 01:21 PM
TransAM Joe's Avatar
ProBuilt Street/Strip 700r4 Transmission, has 0 miles. Started with the preferred 1988+ core with all Dana's modifications good to 575 hp and ready to drop in. Has AN fittings and S/S braided hose installed for for cooler lines.
Street Edge 9.5" Converter 3000 stall new in box, never used.
Scat 153 tooth SFI approved flex plate, one piece RM seal,new, never used.
FlexCool Trans Cooler is new, but mocked up on a/c condenser, a few outside fins got bumped, but would not impair 100% functionality.
Lubrication Engineers 7500 Monolec Trans fluid, 12 quarts (this is the magic formulation Dana talks about) worth over $100
$1650 plus shipping(read below), but prefer local pick up due to the weight and cost of shipping for the package for but will split for the right money, or trade for T56 conversion setup.
PayPal preferred
If you want it shipped, determine what carrier you want to use and the origin zip is 65010, shipping will be freight collect(you will pay carrier upon delivery), class 80 and expect the pallet to be 250lbs.
I have well over $2000 in this so not looking for low ballers or tire kickers
Moving on to a T56 setup is the reason for selling.
Old Sep 23, 2008 | 01:36 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Re: ProBuilt 700r4 0 miles and new edge converter
Shipping to 11795? I have been looking for a good strong 700R4. Is the gearing all the same as the stock ratios or are they modified?
Old Sep 23, 2008 | 01:42 PM
gearing is the same as stock, I will have to get back with you on shipping.
Old Sep 23, 2008 | 01:48 PM
Engine: 388 Carb
Axle/Gears: 4.10
Thanks, Also do you have all reciepts? What was the stall converter stalled for? I have a 388CID with about 450h.p estimated the cam is a comp cams- NX284. I also have 4.11 gears in the rear. Would this be a good stall converter for me?
Old Sep 23, 2008 | 01:52 PM
Yes have all receipts, converter is stalled for 3000 rpm. Andre at Edge converters will restall the converter for what ever you want for a small fee. I am not familiar with your setup and don't want to give you poor advice so I will let you determine what is right for you.
Old Sep 24, 2008 | 09:26 AM
bump
Old Sep 25, 2008 | 08:54 AM
gdubya038's Avatar
how many spline is the tc 27 or 30????
Old Sep 25, 2008 | 09:16 AM
30 splines
Old Sep 25, 2008 | 11:22 AM
Anybody before it goes on eBay? Will separate
Old Sep 25, 2008 | 09:10 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Just some info for you.....Andre has a dyno that puts 450 ft lbs of torque to the converter for the stall speed. We had a 30 min conversion when he was doing mine.
But for you. I need a transmission but just got the front end redone.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
italiano67
Dec 11, 2016 09:21 AM
69 Six Pack
Oct 5, 2015 07:51 PM
