CLEANING OUT THE GARAGE
Transmission: t-5
All parts don't include shipping. I will try to get back to you as fast as i can. If you like to have any more pictures just ask. thanks for the larger items i would like to have them picked up or i can meet you for some $. please call, text or email with any questions. 262 745-2432. My name is jerry. If you want to trade anything, im looking for drag radials for 16inch rims, bolt in 6 or 8 roll cage, slicks and skinnys, k-member, 1 gallon fuel cell, braided lines, AN fittings and fuel pressure regs. Fuel cell with sub, a1000 pump.
IF I DONT HAVE ANYTHING LISTED THAT YOU WANT, JUST ASK. I MAY HAVE A FRIEND THAT HAS WHAT YOU ARE LOOKING FOR.
1.) 7, 6 inch forged 4340 H beam rods. Small journal. Each rod has been magnafluxed, x-rayed, and sonic tested to ensure the best quality. They are CNC machined, shot-peened and stress-relieved. Each rod was weight matched to +/- 2 grams when they were stroker clearanced. They have arp 7/16" cap screws and are set up for full-floating with A18 bronze bushings. Both ends are stock small block size (.927 PIN / 2.00 ROD) so you don't have to worry about them fitting properly or having to buy "special" parts to make them work. THESE RODS HAVE NEVER BEEN IN A MOTOR YET! The machine shop didnt like one rod during clearancing so when they called the maker and they just sent out another complete set. These rods weigh 618.4 +/- one gram. You will just have to call the maker to buy one rod about 620 and clearence it. reg price is $300 -------------------------- im asking $150
2.) comp extreem energy soild roller cam. Only 4 months old. Reason for selling is bought some new heads so i went bigger! I was running this on a sbc 400, tpi, with 6lbs of boost. Also will work well with nitrous. Cam sounds great! very streetable. went low 11,s. Paid $350------------asking $150
small circle base.
lobe sep. 113.0
gross valve lift intake .565 exhaust .571 on a 1.6 rocker
cam is installed at 109.0 intake center line.
duration @ .050 intake 236 exhaust 242
3.) sbc 400. casting 509. 2 bolt main. (It is said to be that the 2 bolts are stronger than the 4 boths on 400's for the fact the outer bolts go into water jackets.) Bored .040 over. Only 10k on motor. Just noticed that the bag had a hole in it so some rust has started. Looks like a hone can clean up, but i would put new cam bearings in it. Stock rods, stock crank, I dont know what type of pistons, (flat tops) with molly rings. Comes with a chrome oil pan and a race pro balencer. It was my back up motor incase mine ever popped. --------------------------asking 400.
4.)sbc 383 stroker. Eagle steal crank, Eagle sir rods 5.7, and keith black hypereutectic flat top pistons .030 over, with molly rings. This set up has been balenced and i do have the 2 peice rear main 153 tooth flywheel to go along with it. I had a fluid damper but im still using it on my new set up. Now for the bad news. 2 pistons are cracked and it cracked the block in 1 cyclinder. 4 bolt main. Everything is still in the block. Roughly 8k on it. It has been sitting on the engine stand for near 2 years. I would recomend going threw everthing and giving it a good cleaning. If you want to get 2 new pistons it will be 70bucks from summit. Part number from summit is uem-9906hc030- how many you need so 2. ------------------asking $ 300
5.) MSD coil for tpi ------------------------asking $20 bucks
6.) Stock tpi distributor, cap roter, brass gear.---------- asking $20 bucks
7.) 749 computer, no memical -----------------------asking $20 bucks
8.) Home made jumper wire set up to convert your stock wiring harness from mass air flow to speed density. Works awesome and no cutting of any wires!! plug and play. comes with a knock sensor and a 2 bar map. ----------------asking $50 bucks
9.) 88 firebird 16 inch charcoal/black color rims with hand polished lip. Honey cone style. verry nice! no tires. --------------asking $300
10.) stock t-5 shifter with camaro ball. -------------asking $10 bucks
11.) flywheel shim sbc 2 peice remain. new in box.--------asking $5 bucks
12.) new in box. Cran cams 3/8 stud polly locks.--------asking $20 bucks
13.) i have 2 Mass air flow sensors the screen are cut out but they work great. ----------------------------------asking $40 bucks for each.
14.) stock sbc 400 rods,(8) and (7) forged speed pro flat top stock bore pistons. everything measures out to be good!! --------asking $100 bucks
15.) 882 cast iron heads. fully ported and polished. One head is cracked on the intake runner. Mainly listing for the parts. Manley "street flo" 202, and 160 valves. comp cams retainers, keepers, and guide plates. They are drilled for steam holes to fit a sbc 400. been sitting on the shelf for a couple years now. I do have flow numbers! -----------------asking $50 bucks
16.) stock torque arm, just upgraded. ----------------asking $10 bucks
17.) drive shaft. stock lenght. good u-joints! ----------asking $20 bucks
18.)10bolt rear end. believe 26 spline axles, possi. 3:23 gear. Disk breaks!
upgraded to a 9 inch this year. ------------asking $100 bucks
-------------IF YOU BUY BOTH rearends $200 --------------------------
19.) 9 bolt rear end.possi, believe its 3:23 gear or something like that. It was my spare but never had to use it. Disk break pulled it out of a 88 gta with 85k. --------asking $150 bucks
20.) stock v-6 clutch and pressure plate. less than 500 miles!! still can read "flywheel side" on it. ----------------asking $ 50 bucks
21.)set of axles 26 spline for a 10 bolt -------------------asking $ 40 bucks
22.)Stock ls1 6spd aluminum driveshaft -----------------------$100
23.)pro 5.0 shifter for ls1 6spd ------------------------------- $150
24.) 99 camaro ss. ls1, 3 channel 10bolt for sale, with ta girdle, stock spline, good posi, with stock gears, makes a little whine, but not to bad, needs breather. $250
25.)Eibach sportline kit only 5k miles for ls1, mounted on struts already, good shape, rears come with bilstein shocks -----------------------------------$250
26.) ls1 McLoed Adjustable clutch master cylinder works great------------ $275
27.) stock 10 bolt rearend housing only, no backing plates, disk breaks-------- $50
28.) Stock axel 3 channel for 10 bolt out of a 99 camaro ss------------------$30
29.) ls1 stock torque arm out of 99 camaro ss-------------------------------$20
30) ls1 stock front sway bar, no end links,--------------------------------- $20
31.) stock gm air dam for 91 camaro speed density--------------------------$20
thanks for looking.
small circle base.
lobe sep. 113.0
thanks for looking.
Car: 1990
Axle/Gears: stock
Re: CLEANING OUT THE GARAGE
do you still have the rear ends? please advise - maybe we can work something out. how many miles on them? how large are the calipers on the disks? thanks
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Car: 92 Z,92 RS,95 SS,00 WS6, 04 XUV
Engine: 383z,350RS, LT1, LS1 ,vortec 4.2
Transmission: 700R4, 700R4,4L60E,4L60E, Auto,
i have some 255-50-16 RA1 toyo's , but there on 16 inch 99 camaro rims , they are like new and if you need other tirs let me know. I want the aluminum ds and the 4th gen rearend. I live near LaCrosse Wi. Les
Car: 1991 Hardtop RS
Engine: 406 Small block
Transmission: TH 350
Axle/Gears: custom fabbed 12 bolt posi, 4:11
I am needing a posi unit, let me know if you would ship one with the axles and gears, 62918. thanks
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Can I get info on the 6" rods, make? model #?
Also can I get some pictures of 14.) stock sbc 400 rods,(8) and (7) forged speed pro flat top stock bore pistons. everything measures out to be good!! --------asking $100 bucks
Thank.
Thank.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Sep 16, 2015 12:37 AM
Randomtask2
Sep 10, 2015 08:37 AM
84 TA NV
Sep 6, 2015 08:02 PM
