[TX] Vortec block and heads, valvetrain parts
Old Jun 1, 2009 | 01:46 PM
longhorn450's Avatar
Car: 1990 Trans Am
Engine: LB9 305...350 or 383 coming soon
Axle/Gears: 4th gen 3.42
LCAs are sold. Still have the Comp Cams Beehive Springs as well as the Vortec heads and block. Email at Longhorn450@aol.com!
Attached Thumbnails Vortec block and heads, valvetrain parts-dsc00431.jpg   Vortec block and heads, valvetrain parts-dsc00418.jpg   Vortec block and heads, valvetrain parts-dsc00419.jpg
Old Oct 6, 2009 | 02:46 PM
Car: 1990 Trans Am
Re: Lakewood Lower Control Arms
I also have a bare 350 vortec block, as well as the heads from this engine. Theyre 906 casting Vortec heads completely bare. I do have the valves and rocker arms as well to be included. Make me an offer on the heads/block! No i will not ship them. Local pickup only please.
*Rear end w/ drum brakes from a 90 Trans Am. Non-posi differential and 2.73 gear ratio. $50 picked up
Old Oct 10, 2009 | 08:16 PM
Car: 1990 Trans Am
also have these comp cams LSx beehive valve springs. brand new never even been installed. asking $165 shipped. Ill throw in 14 774-16 Comp Cams retainers if you buy the valve springs for free, I lost two of them. They're 175 before shipping from jegs. you wont find a cheaper set on the internet brand new.
Attached Thumbnails Vortec block and heads, valvetrain parts-dsc00433.jpg   Vortec block and heads, valvetrain parts-dsc00420.jpg
Old Oct 10, 2009 | 11:59 PM
buymytransam's Avatar
Car: 2005 Audi A4 Avant
Engine: 1.8T
Still have the control arms?
Old Oct 11, 2009 | 08:09 PM
Car: 1990 Trans Am
yep ive still got them. never even been installed.
Old Oct 11, 2009 | 08:36 PM
436efi's Avatar
PM sent on your LCA's
Old Oct 22, 2009 | 03:02 AM
Car: 1990 Trans Am
bump.
Old Oct 22, 2009 | 05:52 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
What lift are the valve springs good to?Will they work with a roller cam?
Old Oct 22, 2009 | 06:40 PM
Car: 1990 Trans Am
yep, can definitely be used with a roller cam. Lift up to .600 depending on application. here ya go:
Description of COMPETITION CAMS 26918-16
LS1 VALVE SPRINGS 918's
Part number 26918 Comp beehive springs
Part number 26918
1.055/1.290 single beehive ovate
I.D. .660/.885
seat load 130@1800
Open load 318@1.200
Coil bind 1.085
rate (lbs./in)313
Titanium retainer 772
Steel retainer 774,783
Excellent Springs for most applications up to .600 lift
Utilizes stock spring pocket and retainers.
I was going to use them with those stock Vortec heads, which I believe due to valve guide interference make them good to .550, but on other heads they can take more lift.
Old Oct 22, 2009 | 07:22 PM
Steve Mack's Avatar
Car: 87 Iroc
Do you have the retainers?
Old Oct 22, 2009 | 07:40 PM
Car: 1990 Trans Am
I do, but unfortunately I lost two or three of them (two i think) and if you buy the springs ill give em to you for free. If you want just the remaining retainers theyre yours for $25 shipped.
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Aug 17, 2015 02:00 PM
1nastygta
Aug 8, 2015 07:38 PM
