[PA] UMI Adjustable Panhard Bar - $80
Old Jul 31, 2009 | 02:58 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Axle/Gears: GM, 3.23 posi
SOLD
Used for less than 2000 miles. Rod end is tight with no slop, just as it was when new. Poly bushing is also in excellent shape and looks almost new.
edit - new price
$80
SOLD
Attached Thumbnails UMI Adjustable Panhard Bar - -bar.jpg   UMI Adjustable Panhard Bar - -rod-eye.jpg   UMI Adjustable Panhard Bar - -bushing-end.jpg
Old Aug 1, 2009 | 01:22 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: UMI Adjustable Panhard Bar
Hey, how's it going? I never understood the reason why a guy would need an adjustable panhard rod. What does adjusting it accomplish? I keep trying to figure it out in my mind, and nothing is coming to me. Thanks.
Old Aug 1, 2009 | 05:18 AM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
It allows you adjust the side to side position of the rear end. When you have all aftermarket suspension pieces (adjustable torque arm, lowered ride height, adjustable LCA's, etc) you could end up in a situation where the rear end is not centered under the car. The adjustable panhard bar corrects that problem.
Old Aug 2, 2009 | 01:07 PM
gtxtra's Avatar
Car: 89TA(red) 89TA(white) 66Belvedere
Engine: 5.0 tpi both TA's 512ci
Transmission: 700r4 in both TA's 727
Axle/Gears: 10bolt 2.73 10bolt 3.23 dana60 3.73
how much shipped to 08854 thanks
Old Aug 2, 2009 | 01:32 PM
Stephen's Avatar
Car: 87 GTA
Even 100% bone stock, the rear end can be off center.
With the stock 16" 245s, I never noticed. Putting on 17"s with 285s, one side was flush with the outermost top edge of the lip, the other side was in 1/2".
So I got a UMI On-Car Adjustable, Double Rod-Ended Panhard Bar. It lined up the rear end & tires perfectly now & i have zero regrets for doing it.
Old Aug 2, 2009 | 03:52 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
$110 shipped with insurance to 08854
Old Aug 3, 2009 | 01:45 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
ttt
Old Aug 5, 2009 | 09:10 AM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
Re: UMI Adjustable Panhard Bar - $80
bump for new price
$80
Old Aug 5, 2009 | 12:35 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Thanks, for some reason what it did, slipped my mind, thanks for the reminder.
Old Aug 5, 2009 | 01:41 PM
kowalzekc's Avatar
How much shipped to 55124?
Old Aug 5, 2009 | 02:01 PM
sjc115's Avatar
Car: 1984 Camaro
Engine: 350, 4bbl
SOLD
J-money
Jan 4, 2019 09:45 AM
Antips16
Oct 30, 2015 06:42 PM
camaro1185
Oct 26, 2015 06:51 AM
Nervous2
Oct 8, 2015 10:53 PM
