High Performance parts
Old Sep 8, 2009 | 07:37 PM
dpmalibu's Avatar
Here are a munch of parts I need to sell:
1) Summit Racing MSD w/ rev limiter (about 1.5 years old) used for 1000 miles. Works great . Nothing wrong with it $100
2) 16" electric fan w/ Derale fan controller $90
3) High flow catalytic converter 2.5" dia. $40
4) FlowTech Crossflow muffler 2.5" inlet/outlet $30 Comes with a new driver side tailpipe. I was able to get it out of the muffler since it was only clamped on. (up for sale again)
5) Ford Taurus fanw/ shroud . Corner broken off shroud $30
8) stock Air box w/ dual air filters ,comes with all plastic side pieces that attach to radiator support $40
9) Summit shift light $20
10) AutoGage 8,000 RPM tach 3.5" dia $25
11) AutoGage temp/oil pressure dual gauge cluster $25
12) Summit Racing 14" Chrome air cleaner (drop base) w/ K+N air filter $50
13) Diehard battery good shape just took out of my 88 Camaro. 690 CCA $40 Pick up only
14) Brand new TRW Front coil springs for V8 part # CS5608 $40
Located in Hatboro,PA
Here are some pics. I have pics of all the parts.
Old Sep 8, 2009 | 09:25 PM
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
Re: High Performance parts
pics of the gauges?
Old Sep 9, 2009 | 07:26 AM
dpmalibu's Avatar
Here are a couple of pics. the gauges worked fine. They also have new bulbs in them.
Old Sep 9, 2009 | 07:35 PM
kthxbai's Avatar
Car: 1985 Z28
I'm more interested in the tach, any pics of it?
Old Sep 9, 2009 | 07:41 PM
dpmalibu's Avatar
i'll send you some pics tomorrow. i have to go to work now.
Old Sep 9, 2009 | 08:13 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
How much for headers shipped to 39465?
Old Sep 10, 2009 | 08:20 AM
dpmalibu's Avatar
Pics of tach:
Old Sep 10, 2009 | 08:44 AM
dpmalibu's Avatar
Has some cosmetic blemishes on one side. I cleaned it up the best I could. I have used it in 2 cars. It works great. Just took it out of my Camaro in June.
Old Sep 10, 2009 | 09:12 AM
dpmalibu's Avatar
Dustytrix PM sent.
Old Sep 10, 2009 | 08:07 PM
Feroluce's Avatar
Car: 84 Camaro T-top
Engine: 350cu Interceptor
how much for the headers shipped to 13748? and the muffler pls,
Old Sep 10, 2009 | 09:46 PM
kthxbai's Avatar
Car: 1985 Z28
im swapping an lt1 and dont know about wiring up my gauges- is this one cable driven or electronic?
Old Sep 11, 2009 | 01:47 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
torque arm mount pics plz.
Old Sep 11, 2009 | 01:44 PM
dpmalibu's Avatar
kthxbai it is a just a regular tach. Its has 4 wires that come off of it. One for the power, one for the ground one for the tach and the last one for the lights. I can't tell you how it would hook up to an LT1. Do a search on the forum and you may find your answer there.
Feroluce i sent you a PM and I will post the pics here as well.
Darkmj16 I will take some pics and post them later. Thanks
Old Sep 11, 2009 | 02:21 PM
DARKmj16's Avatar
Engine: 305 tbi
ok thx
Old Sep 11, 2009 | 07:38 PM
dpmalibu's Avatar
Old Sep 11, 2009 | 07:41 PM
dpmalibu's Avatar
Pics of Catalytic converter:
Old Sep 11, 2009 | 07:46 PM
dpmalibu's Avatar
Pics of coil springs and Taurus fan:
Old Sep 11, 2009 | 07:47 PM
DARKmj16's Avatar
Engine: 305 tbi
CONSIDER IT SOLD!!!!!
Old Sep 11, 2009 | 10:52 PM
motionwannabe's Avatar
PM sent. thanks
Old Sep 12, 2009 | 12:08 PM
dpmalibu's Avatar
Pics of shift light:
Old Sep 12, 2009 | 09:55 PM
dpmalibu's Avatar
sale pending on torque arm mount,headers and muffler.
Old Sep 16, 2009 | 03:49 PM
dpmalibu's Avatar
ttt
Old Sep 17, 2009 | 11:17 AM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Is the Ford Taurus fan sold? Can you give me the shroud dimensions? Thanks.
Old Sep 17, 2009 | 02:50 PM
dpmalibu's Avatar
still have it. dimensios are 23" L x 18"H x 4.5" Deep
Old Oct 3, 2009 | 03:18 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
do you have th air hose for that style of aircleaner?
Old Oct 3, 2009 | 07:26 PM
dpmalibu's Avatar
No. I have the housing and the filters and that's it.
Azrael91966669
25
Jun 20, 2017 04:04 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
TA8487
Aug 16, 2015 12:21 PM
1nastygta
Aug 8, 2015 07:38 PM
