[Sold] 9 bolt
Old Sep 9, 2009 | 04:15 PM
tim726's Avatar
Want a title? Post!
Car: Firebird Formula
Engine: 5.7
9 bolt
9 bolt rear, 3.27 gear, posi still works. Has 4th gen PBR brakes installed $100.00. Located 32780 (Florida), contact tim726@cfl.rr.com
Old Sep 9, 2009 | 04:17 PM
Stephen's Avatar
Car: 87 GTA
Re: 9 bolt
FYI....89-92 9-bolts came stock with PBR brakes, so yours aren't "4th gen brakes".
Old Sep 9, 2009 | 04:29 PM
Twin_Turbo's Avatar
Re: 9 bolt
I thought 90s up didn't have 9 bolts anymore? I know of 2 5.7 GTAs, a 90 and a 92 that both have a 10 bolt.
Old Sep 9, 2009 | 04:41 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 9 bolt
I think like halfway through 90 they switched to the 10 bolts...
Old Sep 9, 2009 | 04:49 PM
Stephen's Avatar
Car: 87 GTA
Re: 9 bolt
Regardless of the 90-92 debate...89 GTA came with PBRs on 9-bolts stock. I sold one a couple years ago.
It is my understanding, there was a 9-bolt shortage in the end, so yes...Some late GTAs ended up with 10-bolts.
Old Sep 9, 2009 | 04:52 PM
Twin_Turbo's Avatar
Re: 9 bolt
I think it's got to be in 90 too that they switched over, 91 & 92 didn't have it an the last 90 I looked at had a 10 bolt too. it was a fully documented car so the rear was stock.
Old Sep 9, 2009 | 05:08 PM
tim726's Avatar
Want a title? Post!
Engine: 5.7
Re: 9 bolt
Actually they are; the rear is out of an 88 GTA. I purchased the rear brakes with a 4th gen Camaro 10 bolt, and caliper brackets for the 9 bolt from Flynbye LLC !
My 88 GTA had the 9 bolt, but with the old metric brakes that had the 'racheting' e-brake that quit working probably 20 years ago !
Old Sep 9, 2009 | 05:15 PM
Stephen's Avatar
Car: 87 GTA
Re: 9 bolt
Not 1990......
1987:
2.73 : 1, 3.23 : 1 (MXO), 3.08 : 1, 3.45 : 1 (MM5)
1988:
3.27 : 1 (MXO), 3.08 : 1, 3.27 : 1, 3.45 : 1 (MM5)
1989:
3.08 : 1, 3.23 : 1, 3.27 : 1 (MXO), 3.45 : 1 (MM5)
1990:
1991:
3.08 : 1, 3.23 : 1, 3.27 : 1 (MXO), 3.42 : 1 (MM5)
1992:
3.08 : 1, 3.23 : 1 (MXO), 3.42 : 1 (MM5)
3rd gen 9-bolts came with PBRs after 89.......
Old Sep 9, 2009 | 05:17 PM
Stephen's Avatar
Car: 87 GTA
Re: 9 bolt
OK.....
In other words, it was only upgraded to the same as later year 9-bolts.
Old Sep 9, 2009 | 05:25 PM
tim726's Avatar
Want a title? Post!
Engine: 5.7
Re: 9 bolt
OK.....
Don't get your panties in a wad; I was only stateing where they came from.
Still for sale; anybody interested ?
Old Sep 9, 2009 | 05:34 PM
Stephen's Avatar
Car: 87 GTA
Re: 9 bolt
Sorry I straightened out the info on that. Yes.....
You updated a 88 9-bolt rear to 89 brakes by putting n 4th gen brakes, that are really only the same as 89+ 9-bolt brakes.
Still have the smaller 27-spline axles in it? Or did up update to the bigger axles too?
Old Sep 9, 2009 | 05:36 PM
tim726's Avatar
Want a title? Post!
Engine: 5.7
Re: 9 bolt
Sorry I straightened out the info that. Yes.....
All stock except the brakes !
Old Sep 9, 2009 | 09:19 PM
petko0's Avatar
Engine: built 350 TPI
Re: 9 bolt
wats the condition, and how much shipped to 60171
Old Sep 9, 2009 | 11:44 PM
tim726's Avatar
Want a title? Post!
Engine: 5.7
Re: 9 bolt
Shipping would be more than it's worth ! It's pretty heavy.
Old Sep 10, 2009 | 03:47 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: 9 bolt
When they went to the larger 11.75" rotors, they also went to the 28 spline axles. Earlier axles were all 26 spline.
ok, bot!
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
