TPI setup, TQ, 416 heads,carb
Car: 86 Iroc-Z
Engine: 310ci soon to be 355ci
Transmission: built 700r4
Axle/Gears: I think 3.08s
I have a complete TPI setup from my 86 Iroc, I no longer need it cause I went Carb.
Harness is cut, Fan, Lockup, and one relay plug was cut out and a new one spliced in. I have the relays to go with it and two new ones, comes with the Dizzy and a new Mod chip, No cap. I most of all the bolts to go along with everthing, Maf is bad I think? Injectors, fuel rail, plenum, runners, knock sensors, lower intake and 9th injector are what I have boxed up in a summit box ready to go. I also wanna keep everything together.
Im looking for atleast 250 plus shipping, have pics also.
Stock TQ converter with 25K, 100 plus shipping or OBO
Stock 416 heads that I started to clean up, the exhaust ports and one of the intake ports I started on. Heads have 57k and are bare but I can include newer springs, lifters and push rods. 150 plus shipping
Rebuilt 193 heads bare, perfect for a truck, 10mi on them, I have the valves and rockers for them also, 100 plus shipping
Rebuilt quadrajet carb with no miles on it, needs to be cleaned up a bit. 20 bucks plus shipping.
I need this stuff gone, Its taking up waay to much space.
Thanks for looking.
Thanks for looking.
Car: 86 Iroc-Z
Re: TPI setup, TQ, 416 heads,carb
No offers??? Forgot to mention everything is neg.
Anyone have a vacc controlled HEI?
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
your qjet carb...... is it electronic or non electronic?
if it's electronic, i do have a vacuum controlled hei.... where in pa are you?
Car: 86 Iroc-Z
I started to dial it in on the motor it was on but never got past idle with it at the time.
I'm in the stroudsburg area.
Car: 2000 astro
Engine: 4.3
Transmission: A4
hmmmm......
i'm interested in the carb. would you be interested in trading for this distributor that i have?
Car: 86 Iroc-Z
Sure, sounds fair. Is it a stock gm piece? I don't need the cap and rotor for it.
Want pics of the carb? I can get them tomarrow afternoon to you're email, just pm me with it.
Car: 2000 astro
Engine: 4.3
Transmission: A4
yes, it's a stock gm distributor, but has been upgraded with a hypertech cap, rotor, and high voltage coil.
i'll get you a couple photos of this distirbutor in exchange for pictures of the carburetor.
thanks!
thanks!
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
