[KY] 305 power pack
Old Sep 21, 2009 | 07:59 PM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
305 power pack
gauging interest in a 305 power pack.. It would Include a set of 113 corvette heads with egr tube,crane 2032 cam,an edelbrock high flow tpi intake, a set of bosh III 22lb injectors, and a burned chip and adaptor for the bigger injectors...proven to build power on the 305 tpi..would like to get $650 out of it all..pm me for more info
Old Sep 22, 2009 | 08:41 AM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Re: 305 power pack
PM sent.
Old Sep 22, 2009 | 10:16 AM
Car: 88gta
Engine: 357
Re: 305 power pack
pms returned!!!
Old Sep 23, 2009 | 01:57 PM
Car: 88gta
Engine: 357
Re: 305 power pack
bump!!
Old Sep 24, 2009 | 02:36 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: 305 power pack
i would love to have just the heads pm me with a price shipped to 43055 for them if you will. unfortunately already have a new set 22#lb hr injectors, a 2032 cam,and siamesed polished intake so i realy onl need the heads alone.
any info on the heads, how many miles are on them? are they ready to bolt up or need some work? valve seals fresh?
Old Sep 24, 2009 | 10:46 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: 305 power pack
How much for the Edelbrock high flow intake? What exactly is included... just the base, or the base and runners? Assuming you were using or have used the base with the 113 heads, the Edelbrock intake isn't for Vortec heads is it?
Old Sep 24, 2009 | 11:38 PM
Car: 88gta
Engine: 357
Re: 305 power pack
sorry would like to sell the whole set up...heads have less than 5000 miles on them...just have to clean off the old head gaskets....
the heads,edelbrock base,cam,injectors,chip...no the base is not for the vortec heads...
Old Sep 25, 2009 | 07:34 AM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Re: 305 power pack
how soon do you need these gone i'm taking a trip in october would be the 16th or 17th that i could come by and pick it all up if that would work, let me know.
any pics of this stuff?
curious if heads were bought new 5,000 ago or straight from the machine shop or what not. also if the base was new, and cam at the same time. injectors new or recondition so on.... thrive on info and pics so if you have anymore that would be great. was the chip for a maf or speed density setup?
Old Sep 25, 2009 | 11:00 AM
Car: 88gta
Engine: 357
Re: 305 power pack
If my car sells I wont need to sell this stuff....this was all for my blue 305'd ta...It was hit before I could use it all...The intake was bought new off a tgo member a year or so ago,It was on the car with runners and ported pletnum when it was hit..a few weeks before it was hit I bought the heads from a wrecked 89 vette.(smashed in the rear)I was told the whole motor was rebuit 5000 miles ago...I pulled the top end apart and it was clean as a whistle inside the motor..I never got to put them on cause of my wreck...the cam came out of my iroc when I bought it...again the motor was rebuilt and he missed a gear and spun a rod bearing....I pulled the cam out and sold the heads..The injectors were reconditioned from fuel injection connection.. These were also on my ta when it was hit...the chip came from tpi parts off of ebay... I dont have any pics but I can get some.....Hope this helps with all questions
Old Sep 25, 2009 | 08:09 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Re: 305 power pack
sounds like a kool deal. just wish i knew for sure about the heads condition hopefully not cracked or anything.
like i said if you can wait until mid October 14-17th anywhere in that time frame i can come with cash in hand to grab it all up on inspection.
as for pics that would be great if you could send some when you get time.
pm me the pics if you will thanks.
Old Sep 25, 2009 | 09:39 PM
Car: 88gta
Engine: 357
Re: 305 power pack
If I still have it, we could work something out..I will pm you some pics..
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
3rdgenparts
Aug 5, 2015 11:57 PM
