[NY] TKO 600 with setup
Old Oct 5, 2009 | 10:41 AM
justanrs's Avatar
TKO 600 with setup
Used TKO600 5 speed. Has only 3000 miles on it.
includes
Transmission TCET-5009
Lakewood blowproof bellhousing w/ clutch fork
Driveshaft
Crossmember for spohn crossmember mounted torque arm, torque arm not included , has DS loop
Speedo adapter,Reverse light switch
Master and slave cylinder if you would like it.
All you need is a clutch and flywheel and you're all set.
1.125x26 spline clutch disk
Everything was purchased brand new, the only use was the 3000 miles i put on it.
No adapter plate just bolts right to bellhousing proper length input shaft and good positioning of shifter. I made a plate to bring the shifter back to the right position in the car.
Whole setup with master and slave cyl and shifter for 2500. Prices all together would be around 3400.
Old Oct 5, 2009 | 07:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: TKO 600 with setup
is it the 3rd gen specific bellhousing with the bracket for the hydraulic clutch slave? Are you sure it's a TKO600 and not a t3550? never seen a tko600 that bolts right to the bell with no adapter plate.
Old Oct 5, 2009 | 08:22 PM
justanrs's Avatar
Yes it is third gen specific 15020 lakewood, has slave bracket and thats what i was using. It is a tko it is direct gm bolt on. look it up tcet-5009. I have had it in the car. The bellhousing has regular straight gm holes or 17 degree tilted holes for T5 but this trans uses straight holes. I bought the transmission from 5speedtransmissions.com, I believe they had just came out with the TKO 600 with the GM input shaft and front retainer when i bought it in last may. I forgot i have one pic in my vbgarage of the bell/part of trans and slave cyl, other pics asap
Old Oct 8, 2009 | 07:04 PM
Dueling73s's Avatar
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
I am interested in this set-up as I would like to keep my IROC a 5 speed. I need to see some details like install pics or whatever you may have as I have not seen this trans in a 3rd gen.
Send me a pm if you wish, thanks.
Old Oct 11, 2009 | 11:50 PM
justanrs's Avatar
posted some pics under my profile in the album section, if anyone wants the torque arm also it will be an extra 150 bucks for that. Ill have more pics tomorrow of it installed and removed from the car.
Old Oct 12, 2009 | 09:37 PM
justanrs's Avatar
Posted more pics of it installed and driveshaft out under my profile in the album. The driveshaft is painted b/c so it should never rust. Hopefully someone will take advantage of this good deal. The only reason i'm selling it is because the cars basically just getting turned into a race car so i built a turbo 400 for it.
Old Feb 22, 2010 | 05:22 PM
Irocz355's Avatar
Car: 88 Iroc-z
Engine: HSR 355ci Cammed, World Heads, Edelbrock Headers, Dynomax Cat back, Lakewood rear suspension, and MSD ignition.
Axle/Gears: 4:30 ratio, Auburn posi, and Moser axles.
Do you still have this?? I PM'd you but no response..
Old Feb 22, 2010 | 06:25 PM
Dueling73s's Avatar
Hey irocz355 I know he doesnt have it anymore because I bought it from him!
Pac J
May 17, 2020 10:44 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
2012sergen11
Oct 13, 2015 07:38 PM
customblackbird
Oct 1, 2015 04:30 PM
tattmann
Sep 27, 2015 05:20 PM
