Mallory Comp 250A (alcohol) fuel pump
This is a lightly used Mallory 250A fuel pump. It was used only to transfer E85 from a fuel container to my vehicle. It has probably pumped 50 gallons of fuel so there is still plenty of life left in it. This thing is a monster in fuel delivery and just what an alcohol car needs. Summit sells this pump for $330 I would like $250 shipped for it. This is a great deal for a practically new pump. Here are the specs from Summits site:
Brand Mallory Ignition
Manufacturer's Part Number 5250A
Part Type Fuel Pumps, Electric External
Product Line Mallory Comp Pump Fuel Pumps
Summit Racing Part Number MAA-5250A
Free Flow Rate 250 gph
Maximum Pressure (psi) 18 psi
Inlet Size -8 AN
Inlet Quantity Single
Inlet Attachment Female threads
Outlet Size -8 AN
Outlet Quantity Single
Outlet Attachment Female threads
Quantity Sold individually.
Notes Pump has -8 AN bypass outlet.
Enhanced fuel flow for enhanced performance.
These Comp Pump series electric fuel pumps are ideal for high-performance street or race applications. They have a high-quality, permanent magnet 12 V electric motor and feature a factory-set base pressure. Intended for gasoline use, each pump assembly features a quiet, high-efficiency Gerotor design that provides stable output. The housings are fully machined and have a special design that allows some adjustment of the output pressure. All Comp Pump series fuel pumps must be used with a fuel pressure regulator. Pumps are available in many different ratings from 60 to 500 gph, with fuel pressures ranging from 4 psi to 100 psi. They're perfect for any carbureted or fuel-injected engine!
Inlet Size -8 AN
Outlet Size -8 AN
toronto formula
Nov 10, 2015 06:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
