[Sold] 200cc Dart pro 1 platinum heads Ported and gasket matched
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Sellling these babys.
These are just as good as a set of afr 195cc heads.
They flow 285-290 on the intake on the flow bench and I have verification that they do.
and 260ish on the exhaust.
They are gasket matched for a 1205 intake gasket and or a 1206.
they have dual 1.437 springs and have part ferrea valves and dart valves. The springs and valves can handle up to a .650 lift cam.
The valves are a 5 angle valve job 2.02 1.60 size\
angled sparkplugs too.
These heads will support roughly 550hp Naturally aspirated pump gas. That is to the flywheel
1050 OBO
this is quite a steal being that afr 195cc are 1500 bucks new. The dart pro1 platinums are 1300-1400 new and these thing are ready to go.
new seals and everything./
1050 OBO
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Re: 200cc Dart pro 1 platinum heads Ported and gasket matched
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
updated with pics. THIS IS a steal.
http://i112.photobucket.com/albums/n...9/DSC00379.jpg
http://i112.photobucket.com/albums/n...9/DSC00385.jpg
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
what rpm can the valvetrain handle? are they setup with guide plates?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Yes they have guidplates. 500-550 lift was where max cfm was attained
I have flow numbers from 150 lift up to .600 I beliee pm me if ur interested
they are gasket matched for a 1205 but 1206 will work on these too
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
you said these have been ported...have any close up pics of the port work?
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Car: 1987 Camaro
Engine: 383
Transmission: Built Up 700-R4
Do you know if the Dart Pro 1's will replace aluminum L98 heads? I'm not sure if the bolt pattern is the same. I currently have a 350 with aluminum L98's and a HSR.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
yes thats what these are for. But the intake will be different than a tpi if you have that
Car: 1987 Camaro
Engine: 383
The Holley Stealth Ram should be the same bolt pattern of a standard TPI, if that is what you mean. I can check mine and make sure, worst case I think I can expand the middle intake bolt holes so that it will fit.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Ya that will work. Let me know if ur interested
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Car: 2000 Camaro SS, 1987 IROC-Z
Engine: H/C/I LS-1, 383 Miniram
Transmission: M6, 700R4
Axle/Gears: 4.11 35 spool 9", 3.73 10 bolt
stinks they are angle plug, or i would buy them prolly right now. They won't fit Eldelbrock headers. Why does everyone get angle plug anyway??
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Angle plugs give more effecient and complete combustion in the heart shape designed combustion chambers. By angling the plug it aims the spark plug towards the exhaust valve which is the hotest part of the chamber. Burning the hotest part of the chamber first and reduces the possiblity of detonation.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Engine: LS1 / L03
i was wondering the same thing.. sorry kowboy but you haven't supplied a whole lot of info, otherwise i'd maybe have snatched them earlier
also no info about flow other than max flow, and then not even noted at which lift that was achieved..
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
i was never asked any other questions but sold lock it up!!!
The saying you snooze you loose comes to mind, no sense in whining about it.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
