parting out SBC engine, and more
Car: 1968 chevelle
for pictures and more information email me. if you don't see a price email me. best offers accepted. all parts are low miles. email me for your small block part needs. i will ship some of the smaller stuff, but will not ship things like the rear.
i will sell the motor complete or part it out.
ORIGINAL 327 V8 TURBO-FIRE L30 OPTION (275HP STOCK). BORED TO 331.6 CI. (30 THOUSANDTHS OVER)
ENGINE DECKED, BORED AND HONED W/ DECKPLATE, BALANCED ROTATING ASSEMBLY, AND DYNOED
10.57:1 COMPRESSION
SPEED-PRO FORGED DOME PISTONS PN: L2166NF30
GM POWDERED METAL I-BEAM RODS
FACTORY FORGED STEEL CRANK (CUT)
CAMSHAFT:
SOLID FLAT TAPPET
CUSTOM HAROLD DESIGN GROUND BY LUNATI on a P55 hardened core (249/255 278/284 .540/.550 106) $150
Crower EDM hole lifters $150
AFR SBC CYLINDER HEADS 195CC ELIMINATORS 1034 $1100
.100 over COMP hardened one piece pushrods $60
1.5 RATIO COMP CAMS ALUMINUM ROLLER ROCKERS WITH POLYLOCKS $225
EDELBROCK PERFORMER RPM AIR-GAP INTAKE MANIFOLD 7501 $190
HOOKER COMPETITION HEADERS 2451 1 5/8 INCH PRIMARIES $100
WEIAND ACTION PLUS WATER PUMP 8240 $50
MARCH CRANK AND WATER PUMP PULLEYS/ BRACKETS. I HAVE THE ALTERNATOR BRACKET AND POWER STEERING BRACKET, AS WELL AS WATER PUMP AND CRANK PULLEY. EMAIL ME FOR NEEDS.
MSD 8360 PRO BILLET READY-TO-RUN DISTRIBUTOR WITH MSD WIRES $200
8202 BLASTER 2 COIL $25
MSD STREETFIRE IGNITION BOX WITH BUILT IN REV LIMITER. I HAVE THE BOX FOR IT TOO. $100
EDELBROCK 1721 PERFORMER MECHANICAL FUEL PUMP $50
EDELBROCK ELITE SERIES TALL VALVE COVERS $40
POWERMASTER 8002 100 AMP INTERNALLY REGULATED ALTERNATOR $80
I HAVE 2 15X7 RALLY WHEELS ON LIKE NEW TIRES
I AM ALSO SELLING 2 15X8 RALLYS WITH NO TIRES
ORIGINAL 3 ROW CHEVELLE RADIATOR
DRIVER QUALITY 1968 CHEVELLE FRONT AND REAR BUMPERS WITH BRACKETS
68-72 COMPLETE DRUM TO DRUM 8.2 10 BOLT WITH EATON POSI DIFFERENTIAL, RICHMOND GEARS 4.11 RATIO. PROFESSIONALLY BUILT. I WILL ALSO INCLUDE LOWER CONTROL ARM RELOCATION BRACKETS BY UMI. $900
i also have a good virgin 400 small block chevy 2 bolt main block, never bored, came out of a running 93,000 mile 1974 caprice.
i am also including the crank, pistons/rods, and 882 heads.
engine sonic tested to .280 - .300 average cylinder wall thickness @ stock bore. VERY THICK BLOCK
sought after casting number 330817 better known as just 817.
just had the engine hot tanked, it's stripped clean. no cracks, sonic tested and ready to be machined
$400 takes the engine engine and all the parts.
EMAIL ME FOR MORE PICS AND INFO.
10.57:1 COMPRESSION
CAMSHAFT:
SOLID FLAT TAPPET
Car: 1968 chevelle
Re: parting out SBC engine, and more
i do have the alternator. yes it will fit that setup, that is exactly what i have on the car now. shipping is 12 dollars. if you use paypal add 3% to the total.
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Part numbers on the MSD Streetfire Ignition box?
Car: 1968 chevelle
Car: 1968 chevelle
everything is sold except:
the 327 shortblock is still for sale:
10.57:1 COMPRESSION with 65cc heads
CAMSHAFT:
SOLID FLAT TAPPET
$1200 obo for shortblock
CAMSHAFT:
SOLID FLAT TAPPET
Terrell351
Jun 13, 2021 01:13 PM
