[MN] 4 wheel disc brake booster and master cylinder
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Im selling a used booster and new re-man master cylinder that came from a 1987 iroc with 4 wheel disc brakes, stock iron calipers in front and stock iron calipers in the back on a 9 bolt rear end. they were painted and are scratched and chipped do to carelessness.
$50 for both + shipping?
does not include lines are prob valve.
located in 55082, MN
Re: 4 wheel disc brake booster and master cylinder
open to offers
Car: 91 rs made into a Z
Engine: 400 hp 355 crate engine
Transmission: World class t5
Axle/Gears: 9 bolt with 327 gears
You still have them i will take them where in MN I live in Winona my cell is 507-458-3932 thanks my name is shane.
PM'ed
bump
$40
Car: 91, Z28
Engine: 5.7 TPI on ZZ4 long block
Axle/Gears: 3.73 posi
Fuelsoul, I have an opportunity to buy an 86 disc rear end complete with 4:11 gears. Needs some work. I want to put it in my 91Z but was not that impressed with the mechanics of the park brake mechanism and the fact that my axle spline is diff so my posi could not be of use if needed. You removed your stock discs, how did they perform when you had them.
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
how much shipped to 10704? yonkers,ny
no dice on either one, bump to the next person
Car: 91 RS, 84 Z28
Engine: 94 LT1, 383
Transmission: 700R4, Super T-10
Axle/Gears: 3:73, 3:56
I am guessing this is still for sale? And you were saying you do not have the proportioning valve?
yup, and correct
bump these need to go
bump
bump
bump
1992 Trans Am
Aug 8, 2015 08:16 PM
