Thread: Dirt cheap TBI parts ,, i want them gone ! make me offer
Intakes
Throttle body w adjustable fuel psi regulator
distributors
Engine wiring harness
PCMs
OBD1 diagnostic cable
fuel gauge
plug wires
sensors
http://desmoines.craigslist.org/pts/1767370318.html
distributors
PCMs
fuel gauge
plug wires
sensors
Car: 78 camaro, 91 camaro both rs's
Engine: 78 has tpi 355, 91 has stock 305
Transmission: 78 has 700r4, 91 has t5
Axle/Gears: 78-2.73,91-3.08
Re: Thread: Dirt cheap TBI parts ,, i want them gone ! make me offer
how much for the diagnostic cable?
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
how much for the fp gauge shipped to 95961? thanks
Car: 91 RS and 89 RS, 99 Tacoma TRD
Engine: 91-L03, 89-350 TBI
Transmission: 91-700r4, 89-T5
Still have the harness for sale? What year? I need it TBI. Auto or manual?
Yes ,still have it.
you can use it with a manual or a automatic , it will work with any transmission electronic or non electronic , it has a plug to plug in a 4l60e transnsmission ,,, if you use a th700r4 or a th400 or a manual transmission you just dont use the 4l60e plug
it will work with any year TBI system , you'd just replace your existing wire harness and computer with this one!
http://desmoines.craigslist.org/pts/2268116971.html
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
How much are you asking for the engine harness?
I would sale the engine wiring harness for $180 , i would pay for shipping and it comes with a PCM 16197427
i bought this harness from fuel injection connection.com for $326.55 the PCM cost me $69.49 ,,the drac module also comes with it and is adjustable to your particular tire size/ gear ratio , the Drac cost me about $50
Its a stand alone harness for streetrods or rock crawlers (plug n play)
look over the pictures and info in the craiglist add and also check out fuelinjection connection.com website and see if this is what your looking for !
if so you can email me and we can make arrangements
thanks from larry webb
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
Looking for a fuel pump and sending unit?
Car: 91 Camaro RS
Engine: 305 TPI conversion.
im looking for the egr, and the hoses and tube that runs from the tbi to the charcoal canister.
Is the harness still available?
