400 sbc and sbc alum heads
Car: 86 camaro
Engine: 406 sb
Axle/Gears: working on that
400 virgin block, 2 bolt main
049 gm phase VI alum heads w/arp bolts and push rods
crane gold 1.6 rockers
4.155 bore wiseco pistons w/ 5.7 rods that are bushed and bolts
manley 5.7 alum rods
holley strip dom intake
$1300 for all
will seperate
all prices plus shipping
$1300 for all
will seperate
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: 400 sbc and sbc alum heads
2 yrs later and I still want the heads....
I'm so close the getting hired...out of work for 18 months.
shoud know in 10 days or less if employment comes thru.
what cam do you run and what are the spring set up at, if they are useable?
If I get hired I will get the heads from you to go on one of my 406's
thanks
thanks
Car: 86 camaro
Engine: 406 sb
i ran a off road z cam, solid, 487/501 i think was the lift, i will be honest i did notice that the deck is no longer perfect, as a street motor the anti freeze ate at some of the water jackets, i would think they would clean up with decking pass tho, do you just want the heads or do u want heads, rockers, intake? i make u a killer deal!
all I will need is the heads really.
do you know about the spring information?...and stud size?
any pict's you can email or pm .
fyi do not ever mix green anti freeze with dexcol, it will eat aluminum at an alarming rate, electrolicis (spelling?)
Car: 86 camaro
Engine: 406 sb
all i know about the springs are they are double springs that came on them, and good to 550 lift, yea i knew better but we had a bad cold snap the other year ( like 0* for a week) and i thought it was better than lose'n the block to a crack, my bad!
shoot me your email and i will get you some pics
my email is c.milligan@verizon.net
also do u still have the 350 4500 stall converter, and who made it?
Car: 86 camaro
Engine: 406 sb
pic sent to email, still got converter, but may be useing in new combo, not sure of brand, i do know that when i got it it was anti-ballooning n2o converter, worked well in my combo, i could use some cash towards motor, i paid 900 for it when i got it, make me an offer if you want it
Did you run these on your 406?
how bad did it overheat????
Car: 86 camaro
Engine: 406 sb
never did, drove around town, hot lappped at the strip, never an issue, but i think the big griffen alum rad played a big part.
Well some this is off, the heads in the picts u sent me do not have the steam holes drilled.
Which means it over heated in street use, was only drag raced, or used on a non 400 block.
Based on the work that needs to be done to fix the pits on the decks,check for warping fix the warp and drill the steam holes, and the price u want I for them, it would be cheaper and more secure for me to go a different direction.
Are you willing to do a money back including shipping if they are not in good shape?
Car: 86 z28
Engine: 305ish
Transmission: 700r4-kickdown cable
Axle/Gears: ill figure out when i pull it apart
looking to get a 400 i was hoping for the block and pistons at least D= whats left of this engine right now?
ill be able to come get it just pm me with a price
Car: 86 camaro
Engine: 406 sb
85 what ever you say, about the hole overheating thing, i know what i had, and what i got, pitted yes, that was my mistake but easy fix. and im not shipping heads back and forth sorry
Car: 86 camaro
Engine: 406 sb
turbo send me a pm with your email and i will get you some pics.
Car: '02 T/A
Transmission: 4l60e
How much for just the block? What machine work does it need? Im in Martinsburg so Id be able to pick up.
Car: 86 camaro
Engine: 406 sb
no machine work has been done at all to the block, machining list needing done to the block is per application. was asking 275 since it was a virgin 2 bolt block.
ambainb
04-25-2016 09:21 PM
Mickeyruder
09-02-2015 02:45 PM
