[WI] disk/disk prop valves
Old Jul 2, 2010 | 07:22 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I have 2 disk/disk proportioning valves that I found sitting in a box in the basement. The box was partially crushed so the metal mounting brackets were a little bent but I bent them back in place and they look alright. The metal brackets were painted gloss black before they were put in the box.
$35 shipped for each (in cont US)
If anyone is interested, I also have a disk/drum proportioning valve and a stock master cylinder. I'll do $27 shipped for both of these.
I'll cover all paypal fees (the seller always should) if you choose to pay that way
Old Jul 2, 2010 | 07:40 AM
Slow Down's Avatar
Re: disk/disk prop valves
Old Jul 2, 2010 | 08:08 AM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Are these still available?
Old Jul 2, 2010 | 08:36 AM
Car: 1987 IROC-Z
Transmission: TH350
Last I saw they were still in bags on the pool table in the basement so yeah they're still for sale.
I take it you would like to purchase one of them? The camera battery has been charging for a while so I'll see if I can get you pictures now.
Old Jul 2, 2010 | 09:34 AM
Car: 1987 IROC-Z
Transmission: TH350
The other one looks exactly like this one other then another larger rubber thing on the front of the prop valve and the bracket probably being bent slightly differently since it would be impossible to get them absolutely perfect again.
Old Jul 12, 2010 | 04:02 PM
Car: 1987 IROC-Z
Transmission: TH350
Nobody is looking for disk/disk prop valves?
Old Jul 12, 2010 | 05:04 PM
Zeromitch87's Avatar
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
yeah i am.
Old Jul 12, 2010 | 06:31 PM
Car: 1987 IROC-Z
Transmission: TH350
How did you want to send payment?
I can get it shipped out the same day I receive payment unless I get the payment after the post office closes.
Old Jul 12, 2010 | 08:26 PM
likeyoumeanit's Avatar
Car: 87 GTA
Transmission: soon to be t56
Axle/Gears: 3.73 posi
I am interested in purchasing one as well, pm me your paypal and I'll send you the money.
Thank you, its refreshing to see someone selling something and not whining about paypal feels and everything else under the sun, the no bs sale is great.
Old Jul 12, 2010 | 10:02 PM
nobreaks254's Avatar
im interested if they will work for my 92
Old Jul 12, 2010 | 10:07 PM
Car: 1987 IROC-Z
Transmission: TH350
You should have a pm likeyoumeanit. I'll go box it up right now.
Old Jul 12, 2010 | 10:19 PM
Car: 1987 IROC-Z
Transmission: TH350
To be honest, I'm not really sure. I think the prop valves are the same from 84?-92 but the 91-92 models had a different master cylinder but I could be wrong.
You, Zeromitch87, and wildjyoung should look into that just to make sure since you all have 90's thirdgens. I'll also do some searching tonight but I won't do all your homework. I'll give you guys(gals?) a day or two to figure things out and make a decision before I move on to the next person (if there is a next person).
Mike
Old Jul 12, 2010 | 10:37 PM
Car: 1987 IROC-Z
Transmission: TH350
Thanks. I don't understand the whole paypal debacle either. It says right on their website that it is free to the buyer and it's the seller that is charged the fee (see link below for proof). I understand that the economy is crap and people want to be wise with their money and get everything they can for what they have but the fee is often only a couple dollars or less so I don't see why it is a big deal.
https://www.paypal.com/us/cgi-bin/ma...y-fees-outside
Old Jul 13, 2010 | 05:22 AM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
i would have gotten back to you faster but i sleep during the day. Can anyone confirm that they will work for 91-92? i have a paypal account if that is how we are doing this
Old Jul 13, 2010 | 07:02 AM
Car: 1987 IROC-Z
Transmission: TH350
It's only been a little over 12 hours so you're not late at all. I work third shift so usually sleep during the day too. No worries man. I haven't heard anything from wildjyoung in over a week so you're next in line.
This is what I've found from my searching...
  • 82-83 cars require swapping the brake line fittings going to the prop valve for metric fittings
  • it seems 84-89 cars and 90-92 cars had different specs for the disk/disk prop valves but I can't find any numbers to see how different they are or what exactly is different. However, if I remember right from past reading (like a year ago), I think the 90-92 disk/disk prop valves had a slightly higher rear brake bias but it was only higher by a couple %
Based on that it seems all third gens require a disk/disk prop valve to properly make the swap to rear disk brakes, but it just depends on what kind of bias you want and that depends on the exact brake setup you're running down to the pad compounds if you're looking for ultimate performance.
If I get paid by 9:00am I can get both prop valves shipped out at the same time.
Old Jul 13, 2010 | 07:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Fitment may be an issue. The threads are different between 84 to early 89, which have M1.0 tube nut threads, and late 89-92, which have M1.5 tube nut threads.
JamesC
Old Jul 13, 2010 | 07:49 AM
Car: 1987 IROC-Z
Transmission: TH350
Thanks James. I just checked both prop valves with the lines from my 87 Camaro and everything went together so both of the disk/disk prop valves are for the 84-89 third gens.
Old Jul 13, 2010 | 11:23 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I'll take one if you still have them.
Old Jul 13, 2010 | 01:08 PM
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I'm going to have to pass, i'm just gonna buy the one i know works for sure good luck though.
Old Jul 14, 2010 | 12:22 PM
Car: 1987 IROC-Z
Transmission: TH350
If nobreaks254 and wildjyoung don't get back to me with a "I'll take it" by midnight tonight then *84TA is next since he contacted me through pm before you posted. If he backs out then you will be next.
Thanks for letting me know. Hopefully your brake upgrade will go smooth. Something I learned the hardway... use LOTS of PBlaster on all the brake fittings you'll be messing with. I'm not talking a couple hours before either, I'd say start a day or two in advance and squirt any time you walk by. haha
Old Jul 14, 2010 | 05:06 PM
I guess I'll have to pass since it sounds like they wont work on a 92
Old Jul 15, 2010 | 12:06 AM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Transmission: TKO-600
i'll take one of the disc/disc valves if you still have it.
Old Jul 15, 2010 | 10:18 AM
Car: 1987 IROC-Z
Transmission: TH350
I just sent a pm to *84TA saying if he wants it he can send me the cash. I'll give him 2 days to respond just like I gave the other guys.
You're on the list rlewi771 but it is unlikely I'll make it to you. *84TA and 406TPI seem intent on getting the prop valve.
Old Jul 15, 2010 | 10:28 AM
rlewi771's Avatar
Car: 86 IROC
Engine: 350 ZZ4
Ok. Just let me know. Thanks
Old Jul 15, 2010 | 10:38 AM
JamesC's Avatar
Mike, to be on the safe side, the guys might might take a peek at the valve in their cars. If it doesn't look like the ones you've posted above, the car has the old cast iron version with SAE lines (which won't match the later valves). I only point this out because 82-83--and 'some' cars as late as 85--are apparently equipped with the old version valve.
The difference can be seen in posts #1 and #2 of the following link:
https://www.thirdgen.org/forums/brak...rop-valve.html
JamesC
Old Jul 15, 2010 | 10:45 AM
Car: 1987 IROC-Z
Transmission: TH350
I never realized it was as late as '85 for some cars. Do you why that was? Did they just keep finding them in boxes around the factory? haha
Old Jul 15, 2010 | 06:26 PM
406TPI's Avatar
Car: 1985 IROC-Z
JamesC
Hummm.....I have an 85 with the old style prop valve as pictured in that thread, however, I am running a LS1 master with the metric lines..they fit the old prop valve fine. I thought the old one had SAE lines?
Old Jul 15, 2010 | 06:50 PM
JamesC's Avatar
Interesting on a couple of notes: 1) My 85 IROC is equipped with the new style combination valve and it does have metric threads. 2) I've never seen/heard of the old style with anything but SAE threads. That said, perhaps the 84+ old style, when they were used, were indeed metric.
Color me befuddled.
EDIT: I took a look at my 82-85 Camaro Parts and Illustration Cat with the following results where discs were concerned:
Valve, Comb (J65) (1982-3) 25511944
Valve, Comb (J65) (1984) 25517739
Valve, Comb (J65) (1985) 25521985
The lines and masters were interesting too:
Tubing (3/16) (Cut as Req.) No p/n
Tubing (6mm) Cut as Req.) No p/n
Cylinder, Master (w/Rr Disc) (1982-3) 18009126
Cylinder, Master (w/Rr Disc) (1984-5) 18011929
So different combination valves in 84 and 85, according to part numbers, but the two use the same master.
"Curiouser and curiouser," Alice cried.
JamesC
Old Jul 16, 2010 | 01:58 PM
406TPI's Avatar
Car: 1985 IROC-Z
Ready to sell me one of them yet? Let me know....
Old Jul 16, 2010 | 02:09 PM
kthxbai's Avatar
Car: 1985 Z28
Axle/Gears: fourth gen 3.42
i guess i'll join the waiting list...
i have an 85 moving up to a fourth gen rear with discs. these sound like they would work fine.
~Steven
Old Jul 17, 2010 | 09:50 AM
Car: 1987 IROC-Z
Transmission: TH350
Thanks again for the info James. Who knows, maybe this will be a better tech thread then a for sale thread.
Yup, *84TA backed out so I'll be sending you a pm shortly with paypal info. If you want to pay another way let me know.
~Steven
I put you down.
Old Jul 20, 2010 | 11:34 AM
kthxbai's Avatar
Car: 1985 Z28
any chance ill get one?
Old Jul 20, 2010 | 12:56 PM
Car: 1987 IROC-Z
Transmission: TH350
Sorry about not getting back to you. Both disk/disk prop valves have been sold and shipped out.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
