[NC] Supercharged LS1 dropout for 3rd gen
Car: 91 Trans Am
Heres a good one for you guys. Im selling my whole drivetrain with all the swap components and everything necessary to drop it in a 90-92 3rd gen with minimal down time
Comes with:
Engine
Trans
All mounts
Complete AN6 fuel system tank to rails with a walbro 255
AN6 trans lines
Complete exhaust, manifolds back
Custom harness fully integrated for a plug and play install to a 90-92 car
Dynotuned PCM
Blower
All ducting w/ billet bypass valve
FMIC w/ mounts
Custom fan shroud to fit the ducting
All belts, hoses and lines, all the small parts that nickle and dime a swap
Cruise module
Throttle and cruise cables
And anything else that I forgot thats related to the swap. All Im keeping is the chassis, interior, rear end and wheels
$5200 complete. I will not separate the first piece from this setup PERIOD. The only possible change I will consider is modifying the wiring for a 82-89 car
Add $450 for the Spohn tubular K-member, WS6 springs, stock A-arms, WS6 36mm hollow swap bar, and brake lines assembled and attached to the drivetrain above
Specific info on the parts in here
https://www.thirdgen.org/forums/fire...arged-ls1.html
Engine is still in the car, so drop by if youd like to take a drive. Its a blast
Shipping is an option, but it wont be cheap
Comes with:
Engine
Trans
All mounts
AN6 trans lines
Dynotuned PCM
Blower
FMIC w/ mounts
Cruise module
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: Supercharged LS1 dropout for 3rd gen
NOOOOOOOOOOOOOOOOOOOOOOO! You are the smartest guy on the board, you do not need any more school. lol
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
If you part the Spohn LS K-Member let me know I'll buy it right MEOW! lol
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I am in need of a spohn K member. The design that takes a regular front strut hookup and NOT an integrated coilover. I've rebuilt all my suspension on my 88 IROC and now need to pull the old motor to drop in somthing much newer. What's your cost and condition of the K-MEMBER? I do not need anything else. Sincerely, Nitro-Nicky
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Brb I'm going to go rob a bank.
Selling / parting the car too Jon? I would be interested in your ac delete heater box if you were.
Car: 1991 Camaro, Best 12.40 @ 115.8 MPH
Engine: LS1, HCI, Headers
Transmission: T56, Monster Stg. 4
Axle/Gears: 7.5" 10 Bolt - 3.73's w/ posi
what wheel horse power does it put down?
toronto formula
Nov 10, 2015 06:17 AM
body, custom, drop, dropout, dropouts, engine, engines, generation, ls1, member, motor, nc, sale, supercharged, transmission
