[PA] TPI set up, injectors etc.
Old 11-04-2010, 11:13 PM
zz4IROC's Avatar
Car: 1988 iroc
Engine: 350 forged crank, pistons, 11.5:1
Transmission: t-5
Axle/Gears: 10 bolt 3.73
Hi guys. Some new or liike new parts for sell. Went to a carb so here it goes:
SLP Runner: like new less than 1000 miles $200
Stock Base Plate $50
Ported plenum: very nice ported for up to 58mm and siamesed for SLP runners $100
Stock throttle body $35
#24 SVO injectors: like new less than 5000 miles:$200
#42 bosch injectors like new less than 10000 miles $200
AFPR CRANE: $25
LT4 Hot cam: $75 like new
all hardware included will sell as a complete package with fuel rails etc. of whatever you want...not doing me any good sitting in my shop so lets make a deal. Pick-up only Norristown PA
Also have "Hawks" ram air for tpi and 2 new K+N cleaners $75
TPI fuel tank pickup and pump still working make and offer
Stock 10 bolt with either 3:08 or 3:23 gears $250
Old 11-05-2010, 12:09 AM
daddy33's Avatar
Car: '85 Camaro
Re: TPI set up, injectors etc.
any pics of the TPI fuel tank setup. What all does it come with?
Old 11-05-2010, 08:55 AM
gcj280's Avatar
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
how many miles are on the lt4 hotcam?
Old 11-06-2010, 11:54 PM
Want a title? Post!
jbzr1's Avatar
Car: 89 Corvette
Transmission: 700 auto
Axle/Gears: 3.08
pm sent
Old 11-07-2010, 12:11 AM
Andy 91GTA's Avatar
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
Can you post some pics of what you have for sale.
Old 11-08-2010, 12:10 AM
zz4IROC's Avatar
Car: 1988 iroc
Transmission: t-5
I will try to get some pictures sometime this week. Anything specific?
Fuel tank is just the pickup for the stock fuel tank with a stock fuel pump on it. Worked fine when i took it apart
Old 11-08-2010, 12:12 AM
zz4IROC's Avatar
Car: 1988 iroc
Transmission: t-5
mileage on lt4 cam is less than 8000. I only took it out because i freshed up the motor and put a carb on it with a more radical cam. Had the cam in a zz4 with stock tpi and ran 13.3 at the strip on drag radials.
Old 11-08-2010, 11:37 PM
zz4IROC's Avatar
Car: 1988 iroc
Transmission: t-5
slp runners sold...rest still available
Old 11-08-2010, 11:55 PM
daddy33's Avatar
Car: '85 Camaro
Does it come with the lines and connector or is it just the fuel pump and bucket area? thanks
Old 11-09-2010, 12:12 AM
zz4IROC's Avatar
Car: 1988 iroc
Transmission: t-5
It inlcudes the pick up.. which sits in the tank and consists of i believe 4 lines. Vent, feed, return, and evap. It does not include the lines that run to the front of the car. The pump has the plug on it and is still attatched to the pick up. Not sure what you mean by "bucket area"
Old 11-09-2010, 09:13 AM
daddy33's Avatar
Car: '85 Camaro
sorry If I sound confusing. But its pretty much the stuff you just said. I would like to see some pics when you get a chance. Doing an EFI conversion so need a electric pump setup. Just let me know
Old 11-09-2010, 10:27 AM
zz4IROC's Avatar
Car: 1988 iroc
Transmission: t-5
Well I have many parts available for your conversion including fuel rails injectors etc. Let me know of anything else you need
Old 11-11-2010, 01:13 AM
zz4IROC's Avatar
Car: 1988 iroc
Transmission: t-5
Runners sold and cam pending sale. Make me an offer. New parts to add to list:
ACCEl 300+ rev limiter set up. Used. low mileage. Complete. $150 shipped
Thumpr cam Roller hydraulic$185 shipped for carb cars only!!! like new less than 1000 Miles!!!!
Old 11-11-2010, 02:41 AM
daddy33's Avatar
Car: '85 Camaro
yeah, pics of the fuel pump setup
Old 11-16-2010, 10:43 AM
TheNewStyle's Avatar
Car: '88 Formula
Axle/Gears: Stock
zz4 cam still available?
Old 11-19-2010, 11:54 PM
Andy 91GTA's Avatar
I am restoring a yellow 92 GTA and I am looking for the following parts:
1. 3 throttle body coolant clamps for 1985-92 TPI cars. I have tried buying them new but the 2 part numbers I have are for worm style clamps. I am looking for clamps in good condition that aren't rusty. Here are some pics:
2. 14 mm bolt and metal clip that holds the alternator wiring. I believe that all 88-92 TPI cars came with these parts. There is no part numbers available for these parts so I am looking for good condition, rust free parts. Below is a picture for the bolt and clip.
Old 11-25-2010, 08:45 AM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Still have ported plenum?
kevin
Old 11-25-2010, 11:17 AM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
I am interested in the bosch injectors. I have a set of 42s I took off my Denali Magnueson setup. Be happy to trade. Also interested in buying what you have straight out if you got pictures. Something showing they are 42s would be nice to as I have been burned by that before.
Old 01-10-2011, 01:21 AM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
would you happen to have the intake manifold, or is that what you have listed as the base plate?
specialized
06-18-2022 09:26 AM
Grant2k
07-10-2018 04:01 PM
Firechicken86
08-12-2015 10:07 PM
Sanjay
08-12-2015 03:41 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: [PA] TPI set up, injectors etc.
