[Sold] TPIS level5 chip
Old Jan 3, 2011 | 01:21 PM
Cody Ashby's Avatar
Car: 1991 Firebird Formula
Engine: 6.0 LQ4
Transmission: TKO600
TPIS level5 chip
Hey guys, i have a level 5 chip from TPIS that i paid $575 for and got 1150 miles of use out of before i decided to switch setups. Jim at TPIS can re-burn these for our cars and it only costs $100. Im willing to take a loss on it just because its sitting here not doing me any good. Lets start the price at $250 shipped, Thanks fellas
Old Jan 6, 2011 | 12:23 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Re: TPIS level5 chip
TTT
Old Jan 6, 2011 | 12:29 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Is this chip for Mass Air or Speed Density?
Old Jan 6, 2011 | 12:54 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
wesilva, i believe it was speed density. I can tell you the car is a 1991 formula that came with a 5.0L TPI from factory if that helps!
Old Jan 6, 2011 | 03:15 PM
wesilva's Avatar
Transmission: 200R4
TPIS says the Level 5 chip is for larger displacement motors running forced induction. Did you run it on your 383? Did you buy it new from TPIS?
Old Jan 6, 2011 | 03:23 PM
Twin_Turbo's Avatar
what combo is it for exactly?
Old Jan 6, 2011 | 05:18 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
yes i ran it with my 383 and yes i bought it brand new with TPIS. I have the receipt still..586 dollars to be exact is what i paid.
Twin turbo not sure by wat combo you mean but this was my setup: 383 stroker, all forged bottom end, 6" h-beam rods, cheap strikeforce aluminum heads. 2.05/1.60 valves, 10.5:1 compression, TPIS Mini ram, 58mm T.B. 30lb injectors, Comp cams xfi280 extreme fuel injection cam. All msd electronics. The chip was custom burned by Jim at TPIS with all the specs of my motor, rear-end,etc...
Old Jan 6, 2011 | 05:26 PM
Twin_Turbo's Avatar
That's exactly what any buyer would need to know, that chip is set up for that engine combo, 700R4 and what axle ratio?
Old Jan 6, 2011 | 05:41 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
3:73 but all that can be changed with a burn for $100 as stated above..^
Old Jan 6, 2011 | 05:48 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
The tune is not set in stone on the chip...I had it reburned twice for the 1150 miles i had it, for cam swap and ring & pinion swap.
Old Jan 8, 2011 | 03:57 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
toppin' off
Old Jan 10, 2011 | 02:33 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
Price drop, $250 shipped
Old Jan 12, 2011 | 05:18 PM
Cody Ashby's Avatar
Engine: 6.0 LQ4
just need it gone..$200 shipped guys
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
bdads
Aug 24, 2015 06:01 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
