[Sold] 9-bolt 7.75" New Parts (3.70 gear set & Install Kit)
Old Apr 27, 2011 | 07:45 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I recently had some troubles with my 9 bolt and I've decided not to keep it. The following are brand new parts. They were sitting under my work bench waiting to be installed in the original boxes. I have excellent feedback here and on eBay. I accept Paypal. All pictures are clickable to larger versions.
3.73 (3.70 stamped on ring) Yukon Gear Set - From Randy's Ring and Pinion- Item Number: YG GM7.75-373BW. Retails $229. These are brand new in the packaging. I've opened the box a few times to inspect them and take pictures. My original invoice shows these as 3.70 ratio, noisey, for a 3.07 and up case. Installation booklet is still in the box. $210 Shipped
Yukon Master Overhaul Kit - From Randy's Ring and Pinion- Item Number YK GM7.75BW. Retails for $230. These are brand new in the sealed packaging. My original invoice shows these do not have side shims and website says no ring bolts. Installation booklet is still in the box. $210 Shipped
Want both? $380 Shipped That's $460 of parts shipped to your door. - SOLD
Girdle with stud kit - From TA Performance- Item Number: TA_1802 & TA 1802-SK. Retails $180 [including stud kit]. These are brand new the box. Studs and fastners are still sealed. Decal and original gasket are still there. This girdle is heavy ~7 lbs and is a monster when compared to the stamped cover. It has drain and fill plugs, bearing preload supports, and adds 1/2 pint to the fluid capacity. ARP Studs are for the main caps to replace the OEM bolts. The other included fastners are for the cover bolts. I've misplaced the instructions but they can be found on the forum. $170 Shipped - SOLD
Old Apr 27, 2011 | 08:37 PM
woodtick45's Avatar
Want a title? Post!
Re: 9-bolt 7.75" New Parts (3.73 gear set, Install Kit, and Girdle w/ studs)
Will you accept a postal money order payment ? I don't do electric money. I'm interested in the girdle w/studs. e-mail woodtick45@hotmail.com
Old Apr 27, 2011 | 09:55 PM
Engine: 383 SBC
Yes, I could do a US Postal Money Order. I'd of course have to make a trip to the Post Office (1 town away) first to cash it before sending any parts.
Old Apr 28, 2011 | 06:56 AM
woodtick45's Avatar
Want a title? Post!
Cool and groovy, if you'll send me an e-mail with your snail-mail address we'll get this done.
Old Apr 28, 2011 | 07:10 AM
Engine: 383 SBC
Email with address has been sent. Sale is now pending on the girdle cover.
I still have the gears and install kit. Anyone interested? Really need to get this moved to clean out garage and afford replacement rear end.
Old Apr 29, 2011 | 06:11 AM
Engine: 383 SBC
BUMP.
Old May 2, 2011 | 04:54 AM
Engine: 383 SBC
I have received the payment for the girdle. I should be able get that cashed and shipped today. I'll send you the information after.
Any takers for the gears and install kit? You'd pay $325 just for USED 3.70s without any new bearings from 9bolt.com or around $470-$480 for the same stuff at Randy's Ring and Pinion.
Old May 2, 2011 | 01:02 PM
Engine: 383 SBC
The cover was shipped today. Should see it Wednesday if it doesn't get delayed. You have email with the tracking number attached.
Old May 4, 2011 | 06:11 PM
Engine: 383 SBC
Bump still got the gears and kit.
Old May 4, 2011 | 08:28 PM
woodtick45's Avatar
Want a title? Post!
The girdle arrived and is in excellent condition, a real pleasure doing business with you, THANK YOU !
Old May 4, 2011 | 08:36 PM
Engine: 383 SBC
No problem please leave feedback raiting. I'll do the same.
Old May 9, 2011 | 08:02 AM
Engine: 383 SBC
BUMP.
$380 Shipped for both (3.70 gears and install kit) That's $80 off retail prices and I'm paying the shipping within the US.
Old May 13, 2011 | 01:53 PM
TrueIroc's Avatar
Car: 1989 IROC-Z 100% Original
Engine: 5.0 TPI
Axle/Gears: 3.08
What kind of troubles did you have with the 9 bolt?
Old May 13, 2011 | 03:27 PM
Engine: 383 SBC
I needed a ratio change for the camshaft, so I wanted to inspect it prior to having a shop put in the new gears. On teardown I found the carrier case has already been machined prior and the posi cones are bottomed out, so I can't get much more life out of it. I also found 2 of the 4 spider gear shafts broken. So instead of using my new parts and additional funds (for a posi carrier) I'm planning on a 9" in the future.
Old May 15, 2011 | 05:20 PM
Engine: 383 SBC
Anyone want to make me an offer on the parts? I'm tired of them sitting next to my computer desk.
I believe I have secured a used 10 bolt replacement so I don't plan on fixing up my 9 bolt currently.
Old May 22, 2011 | 09:47 AM
Engine: 383 SBC
Bump. Any offers?
Old Jun 7, 2011 | 05:25 PM
tcollinsjr's Avatar
Car: 1988 Firebird Formula
Engine: LS 6.0
Transmission: th400
Axle/Gears: ford 9in 4.11
How much for gears and install kit? very interested.
Old Jun 7, 2011 | 07:59 PM
Engine: 383 SBC
Sorry sold them last week. Topic is marked as sold.
hectre13
Dec 11, 2023 08:14 AM
italiano67
Dec 11, 2016 09:21 AM
86IROC112
Aug 17, 2015 02:00 PM
dhonda200
Aug 11, 2015 11:50 PM
1nastygta
Aug 8, 2015 07:38 PM
