A/C delete motor, wiring harness, 3 prong resistor
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
i decided to use my original blower motor and resister and harness.
so im selling the A/C delete blower motor, the 3 prong resistor, and the complete wiring harness, UN-cut, with firewall gromet still intact.
I will get pictures later today.
$50 + actual shipping.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: A/C delete motor, wiring harness, 3 prong resistor
You wouldnt by chance have the plug for the hose that between the motor and the 3 prong piece that mounts in the box. I lost mine while I was redoing it and cant find it along with the 2 clips at the bottom of the box
Engine: 4.3 Turbo
Transmission: 4L60
Engine: 4.3 Turbo
Transmission: 4L60
you do realize that the blower motor from an AC setup won't fit the non ac box right? The wiring of the ac setup can be used, in fact the blower will use the high speed relay for a much more effective fan than the normal non ac setup & wiring. Make sure you don't need the motor before you sell it
Engine: 4.3 Turbo
Transmission: 4L60
bump
BikeFarm
Aug 11, 2015 11:35 PM
