[WV] Comp Cams Camshaft
Old Aug 3, 2011 | 09:09 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
Comp Cams Camshaft
Comp Cams
Chevy 262-400 c.i 8cyl. 1955-1998
Hydraulic Roller
RPM Range 1500-5500
Valve Lift 0.474in 0.474ex
Duration @ .050 Lift 220in 224ex
Lobe Separation 111
I want $200.00
Cam has only 500 street miles on it going more radical with the car. If you need any other info or pics just let me know
Old Aug 5, 2011 | 10:06 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
Re: Comp Cams Camshaft
Bump
Old Aug 6, 2011 | 09:01 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by iroc1014
1955-1998
Hydraulic Roller
OEM or retro fit cam?
Old Aug 9, 2011 | 10:31 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
its oem
Old Aug 13, 2011 | 08:00 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
bump
Old Aug 22, 2011 | 10:31 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
bump
Old Aug 24, 2011 | 01:48 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
will this cam be computer friendly and if yes will it work on a stock 1989 350 L98 TPI with stock valve train or is this cam more aggressive needing tougher springs
Old Aug 26, 2011 | 12:36 AM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
Yes it is computer friendly i had it in my TPI 350 but needs springs i have the matching springs have only 500 miles like the cam i will sell to
Old Aug 26, 2011 | 09:40 AM
cwp2's Avatar
Want a title? Post!
Car: 89 Firebird
Engine: 3.4
how much for springs and cam shipped to 51105?
Old Aug 26, 2011 | 09:23 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
pm sent
Old Sep 1, 2011 | 09:35 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
Make an offer on cam and springs
Old Sep 9, 2011 | 05:57 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
bump
Old Sep 10, 2011 | 02:09 PM
SXN's Avatar
SXN
Would the cams and springs fit a 305 from an 84 TA?
If so how much shipped to postal code T6V0B9
Old Sep 10, 2011 | 06:54 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Just helping out a fellow member.....
Lingenfelter sells an inexpensive kit to make this or any other factory style roller cam a retrofit into earlier non-roller blocks. You have to purchase the retro-fit rollers plus this kit and your good to go. I've personally done it a few times.
http://www.lingenfelter.com/mm5/merc...egory_Code=C30
Old Sep 30, 2011 | 05:16 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
bump
Old Oct 3, 2011 | 07:35 PM
DiabloWS6's Avatar
can you give me the cam part number
Old Oct 8, 2011 | 07:45 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
part number is 08-413-8
Old Nov 13, 2011 | 06:03 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
bump
Old Nov 23, 2011 | 07:00 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
Springs only are SOLD still HAVE cam
Old Jan 13, 2012 | 11:01 PM
iroc1014's Avatar
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
bump
Bubbajones_ya
Jul 6, 2024 08:32 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
sandman92084
Sep 12, 2015 10:27 PM
