[Sold] Permacool maxi cool 6 pass trans cooler with FAN! and temp switch!
Old Aug 17, 2011 | 06:03 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Selling one of my trans coolers, it barely has any miles it. Cooler was used for a couple of months after an engine/trans swap and then car was stolen. Its been sitting around and car was barely driven as i was tuning it. Car had a 3000 stall 700r4 and a 460hp 383 HSR which is now gone but the cooler kept the trans temps down since car was mostly street driven.
Cooler is for sale! this is the cooler which is no longer sold from summit
http://www.summitracing.com/parts/PRM-12211/
Trans cooler thermo switch
http://www.summitracing.com/parts/PRM-18900/
I paid $143 for this cooler and then $40 for this automatic switch to turn the trans cooler fan on at 180on and 165off. I have all instructions for the cooler as well as the thermoswitch. The fan on the cooler pushes ALOT of air from such a smaller cooler im actually surprised.
Im asking for 100$ total plus shipping, or shoot me a resonable price. Both of these things cost 200$!!! thats 1/2 off the price! I will even throw in 6ft of hayden 5/16" rubber transmission cooler hose (still in its package) to sweeten the deal!
Old Aug 19, 2011 | 10:26 AM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Transmission: Auto OD-5spd
Axle/Gears: 3.73 both cars
Re: Permacool maxi cool 6 pass trans cooler with FAN! and temp switch!
$100 shipped and it is sold. Would just need paypal address and money sent imeadiatly
Gary
Old Aug 19, 2011 | 11:52 AM
Car: 87 TA clone
Pm sent
Old Aug 19, 2011 | 12:05 PM
gcpoland's Avatar
Car: 86 MCSS-87 Z28
Money sent
Old Aug 19, 2011 | 07:29 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
did you run this along with the stock trans cooler or just this by its self? Im having problems keeping my 700r4 uner 200 with a 12" yenk 2800 stall...im running a big b&m cooler with the stock cooler but i need to change something. wish i was faster on this deal. any advice would be well needed tho. thanks
Old Aug 19, 2011 | 08:26 PM
C409's Avatar
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
..... If your stock cooler is the one in the radiator side tank it is heating your trans oil ... bypass it and run the B&M by itself ........ something I recently found out about the 700R4 is that the flow is diminished to the cooler when the converter clutch is NOT locked ... in other words , the greatest flow to the oil cooler is when the converter clutch is locked .....
Old Aug 19, 2011 | 09:45 PM
Car: 87 TA clone
I ran 2 coolers in series to cool my 3000 stall 12" converter. Dont use the stock cooler in the rad, it heats the fluid and it wont ever be lower than engine temp since its in the rad.
Bypass the stock rad cooler, run the fluid right into the external cooler. I had mine come out from the trans to the B&M cooler then right into the permacool cooler and then back to the trans. One cooler by itself is not enough for my application. So i had to run 2 of them. If anyone wants my B&M cooler id sell it cheap. Its the 24,000 GVW one.
I was also running a steel deep pan (deepest available which is 2 qts i believe) and i would suggest getting an aluminum cast trans pan and tapping it for a temp sender for a trans temp gauge. You want to know the fluid level in the pan and not the lines bc it will give you a better idea of how the overall trans is doing. Lines coming out of the trans is heated from the converter slipping so the fluid will be hotter than the pan fluid, then the line coming back to the trans is cooler than the fluid in the pan (bc its coming from the cooler).
Old Aug 19, 2011 | 09:47 PM
Car: 87 TA clone
Permacool trans cooler is SOLD!
B&M is for sale if anyone is interested
eightsixseven
Dec 16, 2024 01:50 PM
The_Phoenix
Feb 4, 2016 07:10 AM
toronto formula
Nov 10, 2015 06:17 AM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
