[NY] Fs 6.0 lq4 Complete
Old Aug 19, 2011 | 11:01 PM
jpgreen10494's Avatar
Car: 90 Firebird, 96 caprice 9c1
Engine: 305tbi, lt1
Transmission: 700R4, 4l60e
Axle/Gears: 2.73, 3.08
Fs 6.0 lq4 Complete
Here I have an lq4 iron block ls2 (6.0L) out of a 2001 GMC sierra 2500hd with about 100k on it when it was taken out, the garage I got it from told me there was either a bent rod or push rod when it was removed. It ran fine but had a knock, it needs a rebuild I didn't take it apart to see exactly what it was that was the issue. It comes with everything manifolds, intake, coil packs, wires as you can see in te link, No harness. I decided to go with a smaller engine for my car so trying to get rid of this. I'm asking $650 obo, pick up only I will not ship, feel free to pm me with any questions thanks!
http://s1192.photobucket.com/albums/...er_media_share
Old Aug 21, 2011 | 12:10 PM
Engine: 305tbi, lt1
Re: Fs 6.0 lq4 Complete
Bump
Old Aug 21, 2011 | 01:15 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
So have you actually heard the motor run? Where in ny are you?
Old Aug 21, 2011 | 01:41 PM
Engine: 305tbi, lt1
I have not, my brother works there and he said it had a knock. reason for the price, I don't wanna sell something that someone cant use. I'm located in rockhill near Middletown.
Old Aug 21, 2011 | 01:43 PM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
the only good part from it are the coils are the best coils you can get higher output than MSD LS1 coils and the block if its a 2001 its cast iron heads not the 317 and the crank is longer which is good if you want to use a later model trans because the crank is longer than most LSX so you can run a th350 400 or 700r4 without a crank space
Old Aug 21, 2011 | 01:46 PM
lunati397's Avatar
To help your sale short block definately a plus forged rods 6 bolt main you cant beat just get a set of 317 heads and its a stout setup
Engine: 305tbi, lt1
It has 317 heads
Old Aug 21, 2011 | 01:48 PM
lunati397's Avatar
then its not a 2001 block they didnt put the 317 all aluminum heads on until 2003 and very very few 2002s
Old Aug 21, 2011 | 01:52 PM
lunati397's Avatar
looks like it would be an 04 because the exhaust manifolds still have EGR and the cable driven TB because in 05 they went to drive by wire and no EGR and in 2003 they had the coils that have the heat sinks on them and are more round (the good coils)
Great block to start a project with capable of 1000hp on stock bottom as proven by 98cobrakiller on LS1 tech he used stock rods and crank and got forged pistons
Old Aug 21, 2011 | 02:02 PM
Engine: 305tbi, lt1
All research I've done says they've put aluminum heads in 2001, im just giving you guys all the info Ive been given. I dont want to sell anything to anyone if it isn't correct.
Old Aug 21, 2011 | 02:09 PM
lunati397's Avatar
it could have been a replacement under warrenty either or a 2004 is better than a 2001 and the aluminum headed ones are the good ones with L92 heads showroom stock cam edelbrock intake that engine is good for 505 hp
http://www.superchevy.com/technical/...arts_list.html
Old Aug 21, 2011 | 02:16 PM
Engine: 305tbi, lt1
Correct me if I'm wrong but it's not a bad price considering.
Old Aug 21, 2011 | 02:34 PM
lunati397's Avatar
I just recently bought an 05 complete for 500 local but thats here in NM ive seen them go for more out east but thats and average price for a good engine I would guess 500 seeing it needs a rebuild
Old Aug 21, 2011 | 02:36 PM
Engine: 305tbi, lt1
They go for $1400 with 60k here
Old Aug 21, 2011 | 02:47 PM
lunati397's Avatar
location location location
Old Aug 21, 2011 | 04:59 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
I used to have an 01 silverado HD with the 6.0. I seem to recall it had aluminum heads. I could be wrong tho. It is a good deal and I'm really tempted to grab it and build a stroker for my 91 down the road. Or maybe even just rebuild it and replace the 5.3 in my current truck. If I have any cash left over after I get my car tuned next week, I'll take it(if you still have it!).
Old Aug 21, 2011 | 05:05 PM
zya5point0's Avatar
Car: 87 IROC
Transmission: auto
Middletown? Are you close to the thruway and 84? It would be easy for me to pick up!
Old Aug 21, 2011 | 05:52 PM
Engine: 305tbi, lt1
I'm about a Half hour from 84 on 17
Old Aug 21, 2011 | 09:34 PM
Pocket's Avatar
Car: 91 Trans Am
Its an 02 or 03
01's and older had graphite head gaskets, 02+ MLS
Cable TB so its 03 or older
Non connected steam ports suggest 03+
EGR was vehicle dependent until 04 when it was completely removed
Besides, its a blown up LQ4 thats had maybe 3 oil changes in its life, from the rust belt and missing alot of big $$$ parts. Since the oil cap is missing and its dripping with water, one can assume the oil isnt so pure. You also have no clue what you've got and like most are tying to get solid gold for a steaming pile, trying to find some slob foaming at the mouth for anything LSx
Id give you $100 tops
As was posted above, the only thing worth money are the coils and since that engine is so rusted, even those cant be guaranteed to be worth anything. Salt somehow gets inside them and corrodes them from the inside at an alarming rate. Ever noticed how 9/10 coil failures on LS1tech happen to guys from the rust belt?
Baloney, any buyer will be looking to save a dollar, esp in this economy. They will also make use of crazy stuff like google which will bring them to places like LKQ which sell good engines with warranty in loads better shape than that heap for 1/3-1/2 what you say "they go for". You cant gauge a value based on the first two ads you see some dreamer posting
Old Aug 21, 2011 | 10:45 PM
Engine: 305tbi, lt1
I didn't ask for anyones opinion on it, it's a classified thread not a opinion one,
Old Aug 24, 2011 | 03:21 PM
Engine: 305tbi, lt1
Bump
Old Aug 24, 2011 | 06:49 PM
Pocket's Avatar
Car: 91 Trans Am
No, you didnt ask for opinions but you did say this:
And you were corrected because it IS a bad price for a core long block
Old Sep 13, 2011 | 07:08 PM
Engine: 305tbi, lt1
Bump new price $500 obo
Old Sep 14, 2011 | 11:59 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
My 2001 LQ4 I bought had the 317 heads
Old Sep 22, 2011 | 04:01 PM
Engine: 305tbi, lt1
Bump $350obo
Old Sep 23, 2011 | 09:36 AM
92RSTPI's Avatar
Car: 1992 RS Heritage
Transmission: WC T5
Axle/Gears: 10 bolt, 3.73
I have (in my driveway) a 2003 GMC 2500HD, 6.0, it is drive by wire. If this is cable, it is older than a 2003.
6speedIROC
16
Mar 15, 2023 08:33 PM
sailtexas186548
Feb 17, 2017 03:07 PM
BDR
Nov 7, 2015 03:05 PM
topteam54
Oct 6, 2015 12:21 AM
MORREALE5
Sep 13, 2015 09:01 PM
