[NJ] Looking to trade rear ends
Old Oct 24, 2011 | 07:32 PM
nhslacrosse2's Avatar
Car: 1991 z28
Axle/Gears: 2.77 posi
i have a 2.77 posi drum rear end out of a 1991 z28. its currently in the car with 118XXX miles on it. it works perfectly and the only reason i want to trade it is the car was converted to a 5 speed so i would like to change the gear ratio. im looking for a 3.73 posi drum or disc. let me know what you have. i can arrange pick up an delivery of the rears if you are not to far away. thanks.
Old Oct 24, 2011 | 08:35 PM
Jake88maro's Avatar
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
Re: Looking to trade rear ends
i have a freshly setup never been ran 4th gen disk brake ten bolt with 373 gears and a worsen locker.. used timken bearings as well
Old Oct 25, 2011 | 08:27 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
I have a 4:11 posi drum, believe eaton Posi or Auburn posi with the locking pin. New branke lines. Would be willing to trade + alittle cash. Rear has work done to it and is setup for street/strip. Let me Know
Going turbo in my car and need a smaller gear
Old Oct 26, 2011 | 05:58 PM
Car: 1991 z28
is the 4th gen rear an inch longer then the 3rd gen rear?
Old Oct 26, 2011 | 06:55 PM
Car: 1991 z28
yeah the 4th gen rears are longer than the third gen rears. what year car is the rear out of because apparently the rears are slightly different lenghts from year to year. im still interested though. were you interested in trading?
Old Oct 27, 2011 | 11:31 PM
tpibird305spd's Avatar
Car: firebird
Engine: 355
Transmission: T-5 NWC
Axle/Gears: 4.11
i have a 3 73 posi drum rear w/new bearings new jegs gears and a factory posi. its a 2 series carrier so you could keep yours for a spare. $300 can meet you half way from lancaster pa.
Old Nov 3, 2011 | 05:12 PM
Car: 1991 z28
yeah i think that is what im looking for at a good price. PM me to discuss specifics, thanks
Old Nov 3, 2011 | 09:00 PM
wastedt/a's Avatar
Car: 94 pontiac firebird formula
Engine: LT1 350
Transmission: auto
Axle/Gears: 3.23 posi
I have the same problem in my 87 ta. I hate driving w those gears haha
Old Nov 3, 2011 | 11:04 PM
wastedt/a's Avatar
Engine: LT1 350
Transmission: auto
Old Nov 3, 2011 | 11:53 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
An inch? More like (a hair under) FOUR INCHES. You can use 4th gen wheels or if you use 3rd gen 16" wheels, they will set right at the outermost edge of the fender lip. Looks good on a stock height car, but very close to rubbing in road dips on a lowered car.
93-97 rears ("LT1 rears") are slightly wider than the 98-02 ("LS1" rears).
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
