[VA] built turbo 383 motor with pt88 turbo setup
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
I decided to go a different route with my car, the motor has less than 100 miles on it with no track passes and has only seen ~7psi of boost one time, it is still brand new and has to be broken in, i have all receipts for the entire setup including machine work
engine is a 4 bolt one piece 350 bored .030
-arp main studs
-eagle crank
-h beam eagle rods
-srp 8.5:1 forged pistons
-top seal rings
-arp head studs
-3 layer commetic headgasket
-fully ported and polished 200cc WP heads
--1.5 rocker arms forgot the brand but heads are clearanced for 1.6
-custom grind hydraulic roller comp cams
--matching comp cam valve springs
-chromoly push rods
-custom fabricated valve covers
-msd ignition wires
-melling racing series high volume oil pump
-compression is at 8.5:1
-edelbrock victor junior intake
-CSU 750CFM carburator
-locked out distributor with magnetic pick up
-6al-2 digital programmable msd box
-MILODON 7 QUART oil pan
-sfi flexplate (forgot brand)
-everything has been profesionally balanced and assembled with all clearances and receipts in hand. I have over $10k in all parts listed but i also want to include
-precisionturbo 88mm turbo aka PT88 .96 exhaust housing
-complete turbo header for t4 with crossover pipe and 3.5" downpipe.
-intercooler pipes and intercooler which i beleive is 36x12x4 or 3
-50mm X02 racing wastegate purchased from vsracing
-50mm BOV
-Mallory boost referenced fuel pressure regulator
-polished extreme velocity carb hat
-proform electric water pump
-4" air intake with K&N air filter
-2 barm MSD map sensor
-turbo drain and feed lines
-snow performance water/methanol injection kit
Basically i want to sell the engine and turbo setup. It is currently in my car and you are welcome to come hear it run. As mentioned above i have all receipts for engine build as well as most receipts for turbo build (i.e. bov, wg, intercooler, etc) The engine is still brand new and has not yet been broken in. My built transmission took a crap so i decided to go a different route, lsx+6spd.
The setup was built to handle ~750hp with ease but wouldn't be scared of getting more out of it with the right tune. This is the recepe for a solid mid 9 second car. I am located in Mechanicsville virginia. I am looking to get $12k for everything that i mentioned which is much much less than what i have in the setup but i am willing to negotiate. shoot me a PM, email or txt 804 516 2197 serious inquiries only and dont expect a joy ride.
-arp main studs
-eagle crank
-h beam eagle rods
-top seal rings
-arp head studs
-chromoly push rods
-msd ignition wires
-50mm BOV
Re: built turbo 383 motor with pt88 turbo setup
ttt
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Willing to seperate turbo side? Looking for everything minus the turbo.
Hot side and cold side, minus the turbo
I custom built them I'm on my phone now with no pics but I have posted many pictures in the power adder section it's somewhat similar to bbsdesigns style but turbo sits where ac compressor used to be
Terrell351
Jun 13, 2021 01:13 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Street Lethal
Aug 13, 2015 08:28 PM
