Chip Burning items
Old Mar 2, 2012 | 06:39 AM
93BlackTa's Avatar
Car: 93 Trans Am, 89 Iroc Convertible
Engine: 383 LT1, 350 LT1 going in the Iroc
Transmission: T56, 700r4
Axle/Gears: Moser 9" w/3.89, 10 bolt w/3.42
Chip Burning items
I have a Burn1 chip burner with cable to connect to your computer. I only used it 3 times. I also have the installation CD which can also be downloaded. $50
I have a piggyback adapter that you can use to plug your original PROM and the new chip into. $25
I have 3 Chips that can be used for programming and will check the PN on them tonight when i get home. $5 ea
PM with any questions
Old Mar 2, 2012 | 09:22 AM
mike22115's Avatar
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
Re: Chip Burning items
Is this very thing I would need to burn a prom?
Old Mar 2, 2012 | 09:26 AM
93BlackTa's Avatar
yes sir!
Old Mar 4, 2012 | 02:11 PM
Maxdtran's Avatar
Car: 91 Z28 5.7
Engine: 5.7 L98
Transmission: A/T 700
Hey 93BlackTA. Are you selling these reprogram items? I have a 91 Z28 and trying to disabled the EGR Diagnose. Since I keep getting the infamous Code 32 (EGR). It's a recall but GM won't fix this problem anymore. If you are selling can you give the items specs? And how much do you want for them? If not then can you assist on help out a fellow Camaro brother on where to get the items and software to reprogram the chips to disable the diagnose?
Old Mar 5, 2012 | 07:23 AM
93BlackTa's Avatar
PM Sent
Old Mar 7, 2012 | 05:12 AM
93BlackTa's Avatar
TTT!!!
Old Mar 7, 2012 | 11:51 AM
Maxdtran's Avatar
Car: 91 Z28 5.7
Engine: 5.7 L98
I'm not sure if you are selling these burning items. Maybe we have a miscommunication. Are you selling the burning prom adapter, prom, and software? If so how much and am I missing anything else to do this? I have a 91 z28 5.7 auto. Let me know?
Old Mar 7, 2012 | 11:55 AM
93BlackTa's Avatar
Yes items listed are for sale...prices are listed at top in first post of thread. The only thing you would need is a program to change your existing tune (tuner cats etc)
Old Mar 7, 2012 | 12:39 PM
Maxdtran's Avatar
Car: 91 Z28 5.7
Engine: 5.7 L98
Okay before going any further. I've go the software Tunerpro RT. Now you said you had 3 empty chips. What EDM ID are they. Because 86-89 are the same and they use 1227165. I have a 91 so 90-92 are 1227730. Let me know before we go any further.
Old Mar 7, 2012 | 12:41 PM
93BlackTa's Avatar
I will check out the chip ID and let you know....if they arent the same you can buy the rest and get the chips you need somewhere else..i will post chip id shortly
Old Mar 7, 2012 | 12:44 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
if you are going to flash burn, you can use a 27sf512, at29c256 depending on you .bin size just adjust offset.
http://support.moates.net/2010/04/05...using-offsets/
Old Mar 7, 2012 | 12:47 PM
93BlackTa's Avatar
yes im pretty sure the chips i used for flash burning were the 27sf512
Old Mar 7, 2012 | 01:29 PM
utilityguy2's Avatar
Make sure you get genuine SST 27sf512 chips from Moates. There are only two places for these discontinued chips as the remaining supply was bought up. I Don't remember off hand the other company.
I recently bought a supply of supposedly genuine SST chips. Wrong! They were counterfeit. They were re-stamped Winbond W27C512 chips which will program OK with Flash and Burn but will not erase. So beware of counterfeits. EBay is full of them and if the are less than $5 they probably are bad.
Old Mar 7, 2012 | 01:32 PM
93BlackTa's Avatar
The chips i have were bought from moates directly when i bought all the hardware...
Old Mar 13, 2012 | 11:37 PM
salem85's Avatar
Car: gunmetal 88 gta 98 yamaha vmax
Engine: l98
Axle/Gears: bw 9 bolt 327
how much for for the whole setup? and would you ship to tenessee?
Old Mar 14, 2012 | 05:01 AM
93BlackTa's Avatar
PM sent!
Old Mar 27, 2012 | 05:33 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
By law, GM has to fix the issue. The EGR is directly related to smog so they have to comply to be able to maintain the air quality.
Old Mar 27, 2012 | 07:12 PM
I think GM charges thousands of people to fix bad EGR valves on their cars every year that are out of warrantee. Even catalytic converters and other emissions parts are only warranted to 100000 miles at least here in the Midwest. But California is a lot harsher so maybe just to clarify for all, what law are you referring too?
Old Mar 27, 2012 | 07:38 PM
I live in Cali. Over here you must be able to pass emissions which meet C.A.R.B.. We have the toughest and most strict air quality standards. I don't know how the law is in other states but isn't a recall from the dealer a free fix? I currently have a recall on my Camaro about the lighting or something in that area. But when I went to GM, they told me that the recall is not in their system, even after verifying through the, IIRC, National Highway Safty website. I never had a issue with my emissions equipment. So I can't say it's mandatory for GM responsible for the repair. It was just a thought that I put out there. I have the luxury of living in a small town. I have no cat, no A.I.R. equipment, and no smog pump. So I'm running the risk of a extremely hefty fine.
Old Mar 27, 2012 | 08:41 PM
Thanks. and as for running the risk... A lot of us do.
Old Mar 27, 2012 | 09:12 PM
I think about 40% - 60% of us members have some kind emissions delete which would be considered illegal. Isn't there a time limit that would make our 3rd gens smog exempt? This year my IROC hit classic status (26 years old).
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
bigjay89gta
Oct 15, 2015 08:04 AM
okfoz
Oct 13, 2015 02:19 PM
meeklay812
Oct 1, 2015 03:46 PM
