Free: Misc. 2.8L V6 parts
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Everything in the next three pictures is free to a good home if you come get it. I'm willing to ship parts, but I might need to charge like $5 for gas money in addition to actual shipping costs.
Re: Free: Misc. 2.8L V6 parts
I haven't decided if I'm willing to let go of this stuff for free (aluminum is like $0.50/lb for scrap).
3100 top end
2.8L MAF sensor
6 LT1 injectors
3100 top end
2.8L MAF sensor
6 LT1 injectors
more free stuff:
-3100 valves and rockers
-bosch platinum plugs (3k mi)
-exact plug wires (3k mi)
-2.8 cylinder head (3k miles since rebuild)
I have a bunch of other random engine parts from the 2.8
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
hold up...You have the whole top end for a 3100?? What do you want for it?? And the spare set of plug wires??
did ur brother blow up the motor again?
There's a catch. I drilled some accessory holes that break into the water jacket on the passenger head. I put sealant on the threads and they didn't leak, but its probably not long-term reliable. The motor spun a main bearing and I built a 3.4/3500 instead.
either ur brother beats on it like a redheaded step child or u guys just dont have the best of luck lol
Car: 1991 Camaro RS
![Mad](https://www.thirdgen.org/forums/images/smilies/mad.gif)
Do you have any of those rockers off the 3100?? There 1.6:1 ratios arent they?
almost forgot how much to ship me out those 24# injectors to 84713
Probably a little of both. Also being way too cheap. The rods probably had 200K miles on them. I had about $600 all said and done in the 3.4/3500 motor.
yeah im basically out in the middle of nowhere on the edge of the desert lol postal service flat rate box muxh better way to go they would fit in the small 5$ flate rate box
ppl say u can use them but ive tried before they dont work, ur best bet is buying a set of sbc 1.6 " roller tiped rockers" they will swap right on, u just need to reuse the pivot ball from the v6 rockers
Fasteddi, if you want to go hybrid I would grab these parts and just replace the one head, when you go to install them. If you were closer I would trade/give you a head to replace it, since I have like a dozen or so 3x00 top ends.
Car: 1991 Camaro RS
TTypecamaro how much to ship those heads and intakes out(44811) is the zip
I do want to go hybrid sometime in the future, im sure it will help the boost shine more.
Its only 6. A flat rate box is a good idea.
TomP
01-08-2001 01:43 PM
