[IN] sbc 377 and th350
Old Mar 9, 2012 | 11:34 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
sbc 377 and th350
i have a sbc 377 that i had in my camaro, it has maybe 50 miles on the motor and trans since rebuild. im looking to sell the motor and transmission together. im asking $2200 obo. the motor and trans are still in the car. call or txt me with any questions 574-309-4408 or pm me
i have college loans that i need to pay off so the motor and trans need to go. there is nothing wrong with them the car is just not sellings to i figured i would try and sell the motor and trans seperate from the car and sell the car as a roller.
1974 sbc 400 2 bolt main
GM steel 350 crank (not turned)
scat H-beam rods
keith black silvolite hypo-forged pistons .30 over
sealed power piston rings
cam motion camshaft
comp cams lifters
trick flow chromoly push rods
harland sharp 1.5 roller rockers
1969 corvette 492 2.02 camel hump heads (gone through w/ 3 angle valve job new valve guides, valves, and springs)
dual spring valve springs good up to .625 lift
mr. gasket and felpro gaskets throughout
edelbrock performer rpm intake
edelbrock 1407 manual choke carb
comp cams double roller timing chain
king HP bearings throughout
GM pumkin distributor with accel coil
taylor 8.5mm spiral core wires
powerbond balancer
168 tooth sfi approved flex plate
mini starter
chrome oil pan
chrome valve covers
chrome timing chain cover
turbo 350 trans with shift kit and kevlar clutches
hughes 2800 stall converter
Old Mar 10, 2012 | 06:36 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Re: sbc 377 and th350
Bump up
Old Mar 13, 2012 | 01:08 AM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
bump make me an offer
Old Mar 13, 2012 | 09:03 AM
92WS6 T/A's Avatar
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
im looking to do a th350 swap in my 5-speed car, consider any trades for the tranny?
Old Mar 13, 2012 | 11:32 AM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Cash only I need to pay off college loans asap
Old Apr 4, 2012 | 09:36 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
need the motor and trans gone $1800
Old Apr 5, 2012 | 06:49 PM
89irocconvt's Avatar
Car: 89 iroc convertable/ 84 z 12 sec
Engine: stock 305 tpi/ 383
what does that set up do in the quarter mile
Old Apr 5, 2012 | 07:08 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
never made it that far to find out. i would hope somewhere in the 11's
Old Apr 5, 2012 | 07:55 PM
who built the motor
Old Apr 5, 2012 | 08:19 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Rankin engine pro did the short block I put the heads and intake on and all the other small things
Old Apr 16, 2012 | 07:50 PM
5.0slayer's Avatar
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
i maybe mistaking but isent a 377 built with a 327 crank, but i could b wrong.
my mistake it is a 350 crank,
Old Apr 16, 2012 | 08:21 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Yea a 377 is a 400 block with 350 crank
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
Damon
Sep 26, 2015 04:29 PM
