081 305 heads completely rebuilt
Old May 1, 2012 | 07:34 AM
Husker Fan's Avatar
Car: 89 Trans Am
Engine: Stealth Rammed 355
Axle/Gears: 10 bolt 3.23
I have a pair of 305 heads off of a 89 trans am 081 casting number.
They have been professionally rebuilt with new springs, retainers, locks, ARP screw in studs, with 1.94 intake valves and stock exhaust valves. They also come with new plugs, new valve cover gaskets, and valve covers. I have a copy of the build sheet to go with them. These heads have less than 500 miles on them. I'm asking $250 obo plus shipping.
Old May 2, 2012 | 04:34 AM
plemon90ta's Avatar
Car: 1990 TA
Engine: 350 in the works
Transmission: th700r
Axle/Gears: 10 bolt Eaton Posi 373
Re: 081 305 heads completely rebuilt
Do you know what shipping to 10543 would be ?
Old May 2, 2012 | 05:19 AM
Husker Fan's Avatar
Car: 89 Trans Am
Looks like shipping to that zip would be around $77
Old May 2, 2012 | 09:28 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
what cam were the spring set up for?
any pictures of the heads and vc's?
If I can use them would you do $300 shipped to 93534?
thx craig
Old May 2, 2012 | 10:08 PM
Husker Fan's Avatar
Car: 89 Trans Am
Yeah if you're interested I'd take $300 shipped to that zip code.
These heads were set up for cam lift up to .500" they were set up for the lt4 hot cam and they worked good, no valve float. i also forgot to mention that they do come with the stock stamped rockers. Here is a couple of pics one of the build sheet and another of the heads, the pic of the heads isnt very good, but i'll try to post more pics tomorrow.
Attached Thumbnails 081 305 heads completely rebuilt-5-1-12-109.jpg   081 305 heads completely rebuilt-5-1-12-123.jpg
Old May 4, 2012 | 10:49 PM
Any more pict's of the inside of the heads and vc's?
Also combustion chambers?
Old May 4, 2012 | 11:20 PM
Husker Fan's Avatar
Car: 89 Trans Am
Sorry I've been really busy and haven't had a chance to take more pics.
But tomorrow I will post more detailed pics of the heads.
Old May 5, 2012 | 08:21 PM
Husker Fan's Avatar
Car: 89 Trans Am
Here's some more pic's
Attached Thumbnails 081 305 heads completely rebuilt-imag0293.jpg   081 305 heads completely rebuilt-imag0295.jpg   081 305 heads completely rebuilt-imag0297.jpg
Old May 5, 2012 | 08:25 PM
Husker Fan's Avatar
Car: 89 Trans Am
Couple more
Attached Thumbnails 081 305 heads completely rebuilt-imag0294.jpg   081 305 heads completely rebuilt-imag0298.jpg   081 305 heads completely rebuilt-imag0299.jpg
Old May 6, 2012 | 10:11 AM
plemon90ta's Avatar
Car: 1990 TA
Did you replace only some of the valves ? Some intakes look different, dimpled ?
Old May 6, 2012 | 12:16 PM
It's hard to see if all the intake valves match, clearly one head has the convex/dimpled valves. The head on the left is hard to see other than I can make out some are convex.
Do all of the intake valves on both heads match?
Old May 6, 2012 | 10:07 PM
Husker Fan's Avatar
Car: 89 Trans Am
Ya sorry about that, the pics are not the greatest quality.
But yes these heads have the exact same new 1.94 dimpled intake valves all replaced at the same time. The exhaust valves were replaced at the same time as well with 1.5 valves.
Old May 14, 2012 | 09:02 AM
Husker Fan's Avatar
Car: 89 Trans Am
Come on guys, these heads are perfect for a 305 TPI build
Old May 18, 2012 | 08:15 AM
Toofpik's Avatar
Car: 91 RS
Engine: carbed 305
Axle/Gears: 3.42 w/posi & disc brake
Pm sent
Old May 18, 2012 | 08:22 AM
Husker Fan's Avatar
Car: 89 Trans Am
Pm received, and replied
Old May 28, 2012 | 10:39 PM
ruiterman's Avatar
Car: 91 Z28, 89 Formula, 85 IROC Z28
Engine: 305 TPI, 305 TBI, 305 TPI
Transmission: 5 Speed, 5 Speed, 700R4
Do you still have these heads?
Ed
Old May 30, 2012 | 09:02 AM
Husker Fan's Avatar
Car: 89 Trans Am
Sorry, the heads are sold
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
KO1
Aug 31, 2015 06:31 PM
