[IL] Stripping '91 RS for drag car
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
I have a complete , running '91 305 TBI / 5speed that I am stripping for a drag car , motor runs good , does not knock or funky oil pressure and clutch engages smoothly . I don't even need the pedal set as I plan on going automatic with it , I plan on letting go of entire drivetrain . Odometer does show 179 ,000 miles so engine will be cheap . If you want to hear it run , I can leave it in until you hear it run . Email me with what you need and I can send you pics . I do not want to ship this stuff . The car is in Goreville , Il . I am an admin at www.ls1tech.com so you are safe from being scammed. My email address is the same as my screen name @yahoo.com..
Engine: ls1
Re: Stripping '91 RS for drag car
It is a 10 bolt but the rear wheels stick out kinda far and I noticed someone had done a weld job on the axle tubes .It might possibly be a 4th gen , I really don't know much about the history of the car . Here is a couple of pics , what do you think? Or it might just be a very wrong offset. It is about to storm so probably not the greatest idea to crawl around it today ....
Engine: ls1
I haven't pulled off the diff cover to get the numbers on the gears yet . But I will next week . I will have get pics for others so I will find out .
Engine: ls1
I have the gas tank sold and will be pulling it tomorrow. Cut off the hack job exhaust today as I plan to run longtubes only . I will pull the diff cover off after the gas tank is gone , it will be be much easier with all the obstructions out of the way .
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
kah992
Aug 19, 2015 02:55 PM
